gauge help guys
ok i ordered the filter sandwhich plate it will be here soon i'm just trying to get all the wiring done inside the car so i'm not drivin around lookin like some slob with wires hangin out all over the place...
i need a wiring diagram so i can find a 12v ignition switch to put these wires into... also what is a good suggestion for another 12v source that i can use? thanks
edit: 94 ej1 sorry
edit: 94 ej1 sorry
It should be as simple as tapping off of the radio fuse in the fuse box. Or if you have an aftermarket radio in the car you could tap off the switched b+ line and also tap into the wire for the radio dimmer to pull power for the gauge back lighting
ok thanks i got that down now they're all wired up... my oil temp gauge is reading engine bay temp cause i don't have the sandwhich plate yet but my pressure gauge is not connected to the sender and the gauge is reading max oil temp it is all the way to the right... help?
