Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
HFP Suspension kit for CSX?
Old Jun 19, 2007 | 06:44 AM
lastlude2k1se's Avatar
Default HFP Suspension kit for CSX?
I notice there are 5 different HFP suspension kits for the 2006+ civic on http://www.collegehillshonda.com
SI coupe
SI sedan
Coupe
Sedan(auto)
Sedan(manual)
I was wondering if all the suspensions were the same fit and just different spring rates for each car, or will there be fitement problems if I buy the wrong one?
Old Jun 19, 2007 | 07:32 AM
IT GUY's Avatar
Default Re: HFP Suspension kit for CSX? (lastlude2k1se)
fitment will be the same... valving and spring rates will all be different..
bottom line:
buy the right one for your car.. closest would be the sedan si
Old Jun 19, 2007 | 12:31 PM
Thanks!
Old Jun 20, 2007 | 08:24 AM
Default Re: (lastlude2k1se)
For some reason the Non SI Sedan(Manual) suspension kit is on sale for 120 dollars cheaper than the rest. What would be the disadvantages if I bought that kit instead over the SI sedan kit for my CSX? The weight difference of the 2 cars is 145 lbs.
Old Jun 20, 2007 | 08:30 AM
IT GUY's Avatar
the weight difference isn't the biggest deal: where the weight is located is a big deal and most of the weight difference is in the front... the springs won't be stiff enough and the strut valving will be off..
buy the kit that is right for your car. (my advice for the 2nd time)
$120 isn't that much to put the correct part on your brand new car... if it was a 15 year old civic.. screw it, use the other suspension if your on a budget... but if you can afford a new car, you shouldn't be a cheap *** when you're buying parts for it
Old Jun 20, 2007 | 11:18 AM
Makes sence, just wasn't too sure what the differences would be.
tc
May 16, 2009 07:32 AM
bs101
11
Mar 15, 2007 07:00 PM
TypeRBoy
19
Feb 25, 2007 01:16 AM
Red_ED8
Suspension & Brakes
May 26, 2006 05:54 PM
Fuster_Cluck
Apr 23, 2006 01:43 PM
