Recomended upgrades for 97Hatch w/ITR Motor?
What are the recomended upgrades for a 97 hatch w/ITR motor?
Such as upgrading the fuel pump, but what kind?
If you guys can give me more upgrade info with specs and reason I'd appreciate it.
No need to go bigger/better than the OE fuel pump unless you need more fuel.
And to need more fuel you need more air.
So unless your upgrading your cams and valvetrain, more fuel won't do you any good.
What mods are you planning to do?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
how about instead of use telling you what to put on your car, (god only knows what the responses are going to be...) you tell us what you want to improve, and we can make suggestions from there.
Well I guess imma keep it some what stock. I just thought things needed to be replace if getting this type of motor like if replacing drums to disk and needing to get the right prop. and cyclinder. So I guess there is no need to upgrade fuel pump,rails or injectors and such huh.
All the DOHC vtec b series fuel pumps are the same, so as long as your swap came with a b-series fuel pump you're fine.
yeah bro thats what im saying. upgrade my dx fuel pump for the itr motor if it dosnt come with one. itll bolt right in right?
vtec92accord
Mar 7, 2007 05:04 AM
slowpokecivic
Nov 9, 2005 09:46 PM
