question about pistons for D series
Old Jun 19, 2007 | 12:17 AM
broketuner-Sol_Si's Avatar
Default question about pistons for D series
If I were to get a set of forged wiseco pistons yielding a 9:1 CR in a y8 would that CR be lower, the same or higher if I put them in a z6? I tried using a CR calculator, but it just confused the hell out of me
Old Jun 19, 2007 | 11:18 AM
Default Re: question about pistons for D series (broketuner-Sol_Si)
help please
Old Jun 19, 2007 | 11:21 AM
doood's Avatar
been there done that
a y8 head has less combustion chamber cc's so it'll be slightly lower in a z6
Old Jun 19, 2007 | 11:23 AM
DecentCivicZ6's Avatar
B A N N E D
yup, Y8 head is like 34cc, Z6 is like 42cc...somthing like that so it will be lower CR. that just means MORE BOOOST!!!!
Old Jun 19, 2007 | 11:30 AM
Default Re: (DecentCivicZ6)
that's what I was thinking but I wasn't sure if compression height would change or not on my z6....here4's the CR calc I was using:
http://www.zealautowerks.com/dseries.html
I've been told it's accurate to within .2 of a CR
Old Jun 19, 2007 | 11:33 AM
doood's Avatar
to get semi-accurate numbers from that you'll need the compression height of the piston and dome cc's. compression height is from the piston, it wont change from engine to engine.
Old Jun 19, 2007 | 11:48 AM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">to get semi-accurate numbers from that you'll need the compression height of the piston and dome cc's. compression height is from the piston, it wont change from engine to engine.</TD></TR></TABLE>
ahh I see. well dish is 11.6 and comp[. height is 1.154"....going to go convert the " to mm and see what the calc. says \
EDIT: came out to about 8.5:1 I think I'll get them
Old Jun 19, 2007 | 11:52 AM
Bense's Avatar
9:1 pistons for a d16y8 will be 8.72:1 in a d16z6
just use 9:1 d16z6 pistons in your d16y8. Low compression is for wussies
Old Jun 19, 2007 | 12:15 PM
Default Re: question about pistons for D series (Bense)
I have a z6....the pistons are meant for y8s
Old Jun 19, 2007 | 12:21 PM
Bense's Avatar
then just use them
Old Jun 19, 2007 | 12:29 PM
Default Re: (Bense)
I plan too
otek // ek.dipn
Jul 27, 2010 07:08 PM
dravesef
11
Nov 12, 2007 05:25 PM
Almost There
Apr 30, 2006 04:22 PM
platinum00
Oct 25, 2004 08:55 PM
pip9
Jul 12, 2004 05:10 PM
