Engine surging/revving (searched, no luck)
Old Jun 18, 2007 | 09:33 PM
daluv's Avatar
Default Engine surging/revving (searched, no luck)
Ive got a 94 CX hatch with a B20B in it. When I start the car, itll sit fine for about 30 seconds then it will start revving/surging from 1500 rpms to 2000 rpms untill my car reaches its normal operating temp (when my water temp guage needle is about 1/3 of the way up on the guage.) As the temperature increases from when I start my car, the surging drops, and when it gets to normal temp, it idles fine at about 700-900 rpms. There is no heater unit or heater lines in the car (all heat/ac lines and motors were removed by the previous owner.) Does that have anything to do with it or could it be something else?
Old Jun 18, 2007 | 09:38 PM
b20beast978's Avatar
check your iacv...clean it and check if the surging still happens
Old Jun 19, 2007 | 02:46 AM
92ehatch's Avatar
Default Re: (b20beast978)
its probably the FITV.
its under the throttle body.
take off the cap (2 8mm bolts, or a phillips driver)
then take a flat head or two and turn the waxy plunger to TIGHTEN it.
tighten it all the way down (dont over do it tho, just snug it up)
test.
and while you are going through the trouble clean the IACV.
located on back of intake manifold.
two 12mm bolts.
clean with brake or carb cleaner.
reinstall and test.
Old Jun 19, 2007 | 05:28 AM
blk2mid2sol's Avatar
Default Re: Engine surging/revving (daluv)
cleaning the iacv
https://honda-tech.com/zerothread?id=1575913
cleaning the fitv
https://honda-tech.com/zerothread?id=1564019
have fun
also check for vacuum leaks if those two fail...
my weird idling was due to my throttle plate not closing all the way
GL
Old Jun 19, 2007 | 07:15 AM
daluv's Avatar
Default Re: Engine surging/revving (blk2mid2sol)
Sweetness dudes! Will do and let you know how it goes!
Old Jul 12, 2007 | 09:52 AM
daluv's Avatar
Cleaned FITV and IACV. Still have the problem.
Old Jul 12, 2007 | 09:58 AM
Boostedb20EH2's Avatar
Vacuum leak time!!
Old Jul 12, 2007 | 10:57 PM
daluv's Avatar
Default Re: Engine surging/revving (Boostedb20EH2)
Vacum lines all intact. No holes in any of the lines. Maybe when I pulled out all of the heating stuff, a sensor in that is now missing and causing this?
Old Jul 12, 2007 | 11:36 PM
crvpimpin's Avatar
thanks blk2mid2sol
Old Jul 13, 2007 | 07:56 AM
daluv's Avatar
Default Re: (crvpimpin)
The fact that when my car gets up to normal temperature it idles fine, tells me that there is no vaccum leaks.
FTNW
Jul 16, 2012 07:28 PM
tpot90
Jun 14, 2009 04:24 AM
NeKe1point0
Feb 18, 2007 02:12 PM
invisible
Dec 1, 2006 12:35 PM
lhd dc2
Mar 29, 2006 04:04 PM
