Little project of mine
Old Jun 18, 2007 | 07:02 PM
R@mon's Avatar
Default Little project of mine
Taking it nice and slow. Here are a few pics of some parts and progress. VQ35 in a 240sx.
Old Jun 18, 2007 | 07:24 PM
mugenEGG's Avatar
SICCCK setup
what about ze rain?
Old Jun 18, 2007 | 07:40 PM
m R g S r's Avatar
Default Re: Little project of mine (R@mon)
ummm hiii
lol holy shiiitttt looks sick!
how much power can the vq handle? is it built or stock? and aren't the 350 tranny's weak?
Old Jun 18, 2007 | 08:01 PM
codenamezero's Avatar
those aluminum bar is not gonna hold it...
and wouldn't the intake manifold sort a too small... i think it needs way more volume?
nevertheless, it would be sick once you reinforce everything i think!
Old Jun 18, 2007 | 08:09 PM
714phil's Avatar
looks pretty cool. how about some details.. what are your goals with it? building it for anything in particular or just for fun?
R@mon's Avatar
Default Re: (codenamezero)
I didn't realize the aluminum bar was for structural support...
and the plenum's volume is almost 2.5 times the displacement of the engine... i think it's just fine. I couldn't think of a design i liked that would clear the hood so i'll be molding in a cowl.
Old Jun 18, 2007 | 08:11 PM
714phil's Avatar
Default Re: (R@mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon &raquo;</TD></TR><TR><TD CLASS="quote">I didn't realize the aluminum bar was for structural support...
and the plenum's volume is almost 2.5 times the displacement of the engine... i think it's just fine. I couldn't think of a design i liked that would clear the hood so i'll be molding in a cowl.</TD></TR></TABLE>
you should look into cosworths plenum for the 350z
Old Jun 18, 2007 | 08:14 PM
R@mon's Avatar
Default Re: Little project of mine (714phil)
I'm building it for fun. Looking for mid 500's on the stock motor. Next stage will be some eagle rods and some wiseco or je pistons and then looking for 700's. I would like to make more after that with a more serious build but it's too far away to even consider right now. Twin t3/60-1's, 60mm gates, tial bov, custom turbo and intake manifolds, 90mm tb, 75lb injectors, standalone (havent decided on one yet), trunk mounted radiator, 3" downpipes and 2.25" dumptubes coming out of the sides in front of the front tires, 24"x12"x4" vertical flow i/c cores with custom end tanks, etc.
Old Jun 18, 2007 | 08:16 PM
R@mon's Avatar
Default Re: (714phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil &raquo;</TD></TR><TR><TD CLASS="quote">
you should look into cosworths plenum for the 350z</TD></TR></TABLE>
I rather build my own parts whenever possible. It doesn't matter if they don't workout that great, i usually end up making something new within a couple of months anyways.
Old Jun 18, 2007 | 08:17 PM
714phil's Avatar
have you ever seen factory VQ rods?
Old Jun 18, 2007 | 08:19 PM
R@mon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil &raquo;</TD></TR><TR><TD CLASS="quote">have you ever seen factory VQ rods?</TD></TR></TABLE>
yes
Old Jun 18, 2007 | 08:24 PM
714phil's Avatar
yes</TD></TR></TABLE>
have you ever seen factory VQ rods... on weeeed??
Old Jun 18, 2007 | 08:32 PM
R@mon's Avatar
have you ever seen factory VQ rods... on weeeed??</TD></TR></TABLE>
Yea, looks something like the on on the left?
Old Jun 18, 2007 | 08:34 PM
R@mon's Avatar
Default Re: (mugenEGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenEGG &raquo;</TD></TR><TR><TD CLASS="quote">SICCCK setup
what about ze rain?</TD></TR></TABLE>
Let it ride! lol It's not a daily so it won't be coming out unless the weather is perfect.
Old Jun 18, 2007 | 09:15 PM
SwappedTURBOegg's Avatar
wow,sick
Old Jun 18, 2007 | 11:37 PM
Dulluthkid_19's Avatar
You sir are a bad *** mother ****** crazy bitch!!! Holy smokes this car is going to be one for the record books.
Old Jun 19, 2007 | 03:53 AM
JDMCRX's Avatar
Default Re: (Dulluthkid_19)
Thats nice man good luck on the project.
Josh
Old Jun 19, 2007 | 03:59 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (JDMCRX)
ummm... jesus.
Old Jun 19, 2007 | 05:08 AM
DfwBB6's Avatar
Default Re: (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">ummm... jesus.</TD></TR></TABLE>
Old Jun 19, 2007 | 05:18 AM
Turbo-charged's Avatar
Default Re: (DfwBB6)
god i wish i had time like that. thats pretty neat
Old Jun 19, 2007 | 06:55 AM
wunfstmax's Avatar
You can put down 500whp if you install some arp rod bolts. I've seen a tread on my350z about the tranny gears, they looked quite stout. It was out of a car that had the APS tt kit, I belive the only problem they were seeing was either the brass ring's teeth or they synchro's teeth had some excessive wear. I'm sure with some really good tuning the a stock 3.5 will do 500whp in a very reliable manner
Old Jun 19, 2007 | 07:34 AM
P.Winkowski's Avatar
Default Re: (wunfstmax)
That car is amazing
great fab work I respect you alot for doing it yourself. Dont listen to some of these
guys there only experience is from reading off this site. Looks great I wouldnt
change a thing
Old Jun 19, 2007 | 07:42 AM
Default Re: (P.Winkowski)
Also I think you maybe underestimating this setup 1000whp should be no problem once the bottom end is done. Hit up Carl Stevens, I think thats his name
Extreme Race cars, hes running about 200 mph on a 10.5 tire with this motor
Old Jun 19, 2007 | 07:54 AM
karmannghia's Avatar
Hope u have a pump for the oil return..Otherwise u gonna go through the turbos every other week.
Old Jun 19, 2007 | 08:56 AM
ZzZCivicZzZ's Avatar
Amazing. Simply amazing. Excellent work, I'll be checking back for more updates. Keep up the amazing work.
