Hot tank or press wash?
Old Jun 18, 2007 | 07:26 AM
AlienKrOZ's Avatar
Default Hot tank or pressure wash?
i have a block that i would like to clean for a build. should i bring this out for a hot tank or just borrow my friend's pressure washer and wash it down? i think his pressure washer is 1200 or 2200 psi.
Modified by AlienKrOZ at 4:46 PM 6/18/2007
Old Jun 19, 2007 | 07:18 AM
AlienKrOZ's Avatar
Default Re: Hot tank or pressure wash? (AlienKrOZ)
anyone?
Old Jun 19, 2007 | 07:28 AM
eddie_ek's Avatar
You should hot tank it, It will look better and cleaner your going to have to work your *** off to get it clean with the power washer.
If you don't have a hot tank bring it to my shop will throw it in for 30 minutes and see how clean it comes out.
Old Jun 19, 2007 | 07:42 AM
Bakeoff's Avatar
It just depends on how clean you want it.... If you're happy with the pressure wash results, go with it.
Old Jun 19, 2007 | 08:20 AM
AlienKrOZ's Avatar
Default Re: Hot tank or pressure wash? (eddie_ek)
where is your shop located at? i'm in chicago, il if your around my area i will hit you up for sure. just that most shops are far away from me.
AlienKrOZ's Avatar
Default Re: (Bakeoff)
is there a big difference from hot tank and pressure wash?
Old Jun 19, 2007 | 08:31 AM
eddie_ek's Avatar
Default Re: (AlienKrOZ)
Im on western ave and peterson, Hot tank you bake the alluminum with hot water and alluminum cleaner and a power washer is just that preasured cold water
Old Aug 17, 2007 | 07:14 AM
b20beast978's Avatar
how much psi can you set a pressure washer to?
Old Aug 17, 2007 | 07:20 AM
AlienKrOZ's Avatar
Default Re: (b20beast978)
depends on which one you buy. usually 1200, 1500, 1800, 2100, etc
Old Aug 19, 2007 | 03:31 AM
LordAphotic's Avatar
since your friend is going to let you borrow it... why dont you try out the pressure washer first... and if that works than great but if it doesnt then send it to get hot tanked.
Old Aug 19, 2007 | 05:39 PM
hootiehoo's Avatar
Default Re: (LordAphotic)
hook up the washer to warm water out of like a water heater or washing machine hot water outlet.
also, most pressure washers let you mix detergents in there. get off the clumps of grime by hand first, spray some safe stuff like simple green all over, and let it soak. then use the hot water and detergent mix. a few cans of brake cleaner to finish it off should be pretty good for most.
Fitz Williams
Dec 15, 2017 11:42 AM
EF9_TryMe
Aug 11, 2010 09:26 PM
EFbomb
Welding / Fabrication
10
Dec 13, 2009 03:39 PM
marcusgnf
Jul 28, 2007 04:24 PM
B16'D DA9
12
Jun 13, 2005 03:53 PM
