Type r injectors US vs JDM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">Although I heard the JDM 99+ injectors were 290cc...?</TD></TR></TABLE>
Indeed, there was some speculation at one point that the JDM ITR injectors were 270/290cc, but I don't recall whether or not that was ever actually proven or dis-proven.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Indeed, there was some speculation at one point that the JDM ITR injectors were 270/290cc, but I don't recall whether or not that was ever actually proven or dis-proven. </TD></TR></TABLE>
Same. I havn't actually seen proof myself. I'll keep my eyes peeled while im over here in Japan though.
Same. I havn't actually seen proof myself. I'll keep my eyes peeled while im over here in Japan though.</TD></TR></TABLE>
Great... please add this greatly needed piece of information to the FAQ as soon as you have confirmed one way or another
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">All b/d series are the same. Correct me if im wrong</TD></TR></TABLE>
nah, D-series is less, but all B-series AFAIK are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">
I've cleaned numerous sets of OEM injectors for customers, every set of B-series injectors have spec'ed out between 23-24 lb/hr, including those found on JDM ITR swaps, including my own from years ago, which was a '00 JDM ITR front clip.
</TD></TR></TABLE>I've cleaned numerous sets of OEM injectors for customers, every set of B-series injectors have spec'ed out between 23-24 lb/hr, including those found on JDM ITR swaps, including my own from years ago, which was a '00 JDM ITR front clip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">They are the same 240cc injectors. Although I heard the JDM 99+ injectors were 290cc...?</TD></TR></TABLE>
If that were true you would't be able to use a 99+ JDM ITR ecu on a USDM motor.
Thanks...what are the h22a?
The reason I ask is I put together an ls/vtec for my brother with p30 pistons, type r complete head and when tuning, the stock injectors are static at 7000rpm.
Pat
Pat
97+ preludes injectors are 290cc and are high imped. so no resister box needed. The tips are black, were as bseries for the most part are orangeish yellow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 »</TD></TR><TR><TD CLASS="quote">Can anybody second that...."no resistor box needed"</TD></TR></TABLE>
Yes, completely plug-and-play.
Sweet, I just picked up a set of h22a4 injectors with black tips for 50$ Candadian!
Thanks everyone and I will let you know if the h22a injecters are enough for this motor!
Pat
Pat
