Help with ECU Codes
Old Jun 17, 2007 | 09:37 PM
My_EFsedan's Avatar
Default Help with ECU Codes
i have my civic sedan with a b20b swap..and an LS ECU.
i was driving home last night from a Grad party. and my car sparked and smoked inside the car..i pop the hood and the motor and around it smells find and seems fine.
inside the interior smells like some wire did some short circuiting..smells so bad..took out my dash today but cant seem to find anything..drove around fine with the dash off. when i put everything back together..now its throwing ECU Codes..1st one> beepppppp fast 7 beeps after> guessing its code 17? 2nd is beeppppp beeppppp beeppppp beeppppp fast 3> guessing its code 43?
can someone give me a graph of a list of what the code is??
and no damnit, i didnt use the search for crying out loud.
Old Jun 18, 2007 | 12:44 AM
Redline130's Avatar
Default Re: Help with ECU Codes (My_EFsedan)
17 is speed sensor I believe. When you drove around without your dash one, the speed sensor wasn't plugged in, so thus the code 17 from your ecu. The speed sensor is located in the gauge cluster.
43 is fuel supply/fuel pump.
Did you check the fuses in the underdash fusebox? Make sure that there aren't any blown ones.
Old Jun 18, 2007 | 02:37 PM
My_EFsedan's Avatar
Default Re: Help with ECU Codes (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">17 is speed sensor I believe. When you drove around without your dash one, the speed sensor wasn't plugged in, so thus the code 17 from your ecu. The speed sensor is located in the gauge cluster.
Did you check the fuses in the underdash fusebox? Make sure that there aren't any blown ones.</TD></TR></TABLE>
when i drove around without the dash i plugged everything in along with the cluster..
code 43 i smelled fuel inside my car..ill check it out thanks.
Old Jun 18, 2007 | 10:04 PM
My_EFsedan's Avatar
k i check the fuse box and a 15 was blown, replaced it, and still throwin both codes. i checked the speed sensor and it was plugged..still throwin both codes.
im thinking a wire is short circuiting somewhere? cause my cluster is going retarded..
can someone help me please and like give a list of what the codes mean?? much appreciation. thanks
Old Jun 18, 2007 | 10:37 PM
My_EFsedan's Avatar
oh and also..when i turn my headlights on, its dim, and the checklight and the others around it comes on..and my windshield wiper is so slow..
cmon HT! i know someones gotta know..i needa get my car running so i can go to school and whatnot
Old Jun 20, 2007 | 09:49 AM
Redline130's Avatar
Check your battery and alternator too see what condition they are in. In the past, when I had a speed sensor issue, I found that my alternator was dying and wasn't providing enough amps for all the needs of my car. Made my ecu throw the speed sensor code among other things. I replaced the alternator, reset the ecu, and everything was all good. Just something for you to ponder on.
Old Jun 20, 2007 | 11:04 AM
My_EFsedan's Avatar
K ill try that...anyone else has any ideas?
zenon8890
Jun 25, 2009 12:03 PM
ntoxicatedtigah
11
Jun 11, 2009 12:57 AM
BoRiCuA
Nov 23, 2004 06:49 PM
usdm420
Dec 11, 2003 02:12 PM
pg_thao
Jun 13, 2002 03:49 AM
