Sunroof question for CRX
i have a 91 crx si and i wanted to change out my sunroof (problems) as all others
but i wanted to knwo if any of the glass sunroofs from earlier modles (eg, ek ect.)
if they would fit
i searched but only found that integras wont fit bc they go inside instead of up and out
any help would be appriciated
thanks
-John
if they would fit
thanks
-John
so your wanting to fix your sunroof but not with an Si one from another car??? That makes nooooooooo sense at all to me. Yes the integra would be easier to find but with an item like this do you REALLY wanna try and ghetto rig it in?? Just get the right one so you don't have to worry about leaks or any other stupid problems.
What they are saying is fix it the right way. If you don't want rust get the carbon fiber one from visionmotorworks.com
EDIT: IT SUCKS
Modified by RockinthEFhatch at 4:38 PM 10/29/2007
EDIT: IT SUCKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch »</TD></TR><TR><TD CLASS="quote">What they are saying is fix it the right way. If you don't want rust get the carbon fiber one from visionmotorworks.com I have it and it has yet to leak on me and works flawlessly.
I had a full carbon-fiber roof on both sides...from the pictures that still using the bottom sheet-metal or am I wrong?
</TD></TR></TABLE>I had a full carbon-fiber roof on both sides...from the pictures that still using the bottom sheet-metal or am I wrong?
i dont believe another civic sunroof will work. you could probly make it work if ur willing to do some fab work but i dont know if it would be worth it. i lucked up and found a good working one for 25 bucks if i went to pull it out. what problems does ur sunroof have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">
No it's not, it's just like a cf hood. I don't know much about how carbon fiber works but I believe the resin is what is on the back. Here is a picture of mine when I got it:
basically the only options are:
1. keep same rusting sunroof
2. buy a used sunroof in better condition that may eventually rust
3. buy a carbon fiber or fiberglass sunroof plug kit (replaces sunroof with a unopenable panel)
4. buy a carbon fiber or fiberglass sunroof panel off the website listed previously (also sometimes
on ebay and there is another seller)
5. weld in a roof skin off a DX of HF CRX
the sunroof is NOT rusted i just wanted to use a glass cap
and also the motor is shot ive taken out the switch and cleaned it / replaced it with known working one
i just asked the question bc i wantd to re[place the cap with a glass one not CF
what i was trying to say was if the opening for the sunroofs are the same (not the entire assembly)
so i could just switch out the caps
i have also tried to do this but did not find anyone that did a swap on it.
i guess the best bet is to get the cf one, but if you do find out what fits, let us know cause i rather have a glass sunroof also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gospeedgo1 »</TD></TR><TR><TD CLASS="quote">basically the only options are:
5. weld in a roof skin off a DX of HF CRX</TD></TR></TABLE>
6. go jdm Yo and glass top it!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">6. go jdm Yo and glass top it!!!</TD></TR></TABLE>
bc i have the 900 to get one, if i could find it!
