bad vibrations during acceleration
Old Jun 17, 2007 | 06:04 PM
DoC-JoneS's Avatar
Default bad vibrations during acceleration
so my car has developed a bad habit of shaking very badly under hard acceleration. it is definetly rotational in nature it shakes the whole front end pretty bad. and the wierd part it is doesn't ALWAYS do it. some times it will some times it will shake very badly, and somtimes, nothing at all. i am very confused and perplexed. it is an automatic and the tranny was serviced at the local dealership about 2-3 months ago. umm...help?
Old Jun 18, 2007 | 04:37 AM
DoC-JoneS's Avatar
Default Re: bad vibrations during acceleration (DoC-JoneS)
i believe it may be a bad motor mount, or mounts. any auto guys ever have this problem? i really hope it's not my tranny or tc.
*edit: could this possibly be a bad balencer shaft belt?*
Old Jun 18, 2007 | 07:42 AM
4drhonda's Avatar
hey man I have a 96 accord lx 5 speed it does the same thing, If you figure it out let me know
Old Jun 18, 2007 | 07:46 AM
TheMuffinMan's Avatar
He knows where you live!
alignment, motor mount, etc
my car vibrates because of an alignment for the most part
Old Jun 18, 2007 | 08:42 AM
Bruce Banner's Avatar
Default Re: (TheMuffinMan)
Dunno if it'll be the mount, usually it would shake like a ***** when stopped if it's the mount, but I dunno.
Old Jun 18, 2007 | 10:43 AM
onelow10's Avatar
mine does the same thing but only between 60 and 70 mph
Old Jun 18, 2007 | 12:32 PM
Schmitey's Avatar
Default Re: (onelow10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelow10 &raquo;</TD></TR><TR><TD CLASS="quote">mine does the same thing but only between 60 and 70 mph</TD></TR></TABLE>
balance your tires
People! There are about a million different things that could cause a vibration...don't assume that your problem has anything to do with theirs and vice versa.
Old Jun 18, 2007 | 01:12 PM
StyLz's Avatar
^^^ What he said. Could be any number of things. I know for myself it was partially alignment and partially my front rotors needed re-surfacing. My car still shakes slightly but only in 2nd gear. I've learned to live with it lol.
Old Jun 18, 2007 | 03:00 PM
DoC-JoneS's Avatar
Default Re: (StyLz)
i just find that it's wierd that it shakes under power but not when i'm out of my power band. i could be in the bottom of any gear and it's fine, at the top i have to hold the wheel pretty tight. i do need to get the tires balanced but i don't think that's it...
Old Jun 18, 2007 | 05:40 PM
itsturbobitoch's Avatar
Default Re: (DoC-JoneS)
Its not a mount cuz when u start it up it would start shaking real bad an would keep shaking, could be unbalanced tires, maybe u need some new ball joints or check all your suspension bolts and make sure they are tight cuz my buddy had a problem with that when he did his lowering springs some of the bolts came a little loose an had play which gave him bad vibrations
Old Jun 18, 2007 | 06:36 PM
Schmitey's Avatar
Default Re: (itsturbobitoch)
I quote myself AGAIN..."People! There are about a million different things that could cause a vibration...DON'T ASSUME THAT YOUR PROBLEM HAS ANYTHING TO DO WITH THEIRS AND VICE VERSA."
His car isn't your friend's car. Nor did he mention anything about being incompetent at lowering his car.
Use your brain and rely on actual facts and symptoms that the original poster mentions...not just what happen to your car, or your friend's car, or your neighbor's boat. We're trying to avoid unnecessary repairs...so don't fuel the problem with your ignorance or prior experience.
Old Jun 18, 2007 | 07:01 PM
PSwagon's Avatar
It might be the inner joint of the CV axle. I had a 94 legend that did that and my 95 lx wagon is doing the same. I'll change the shaft and update you all.
Old Jun 18, 2007 | 07:33 PM
DoC-JoneS's Avatar
Default Re: (PSwagon)
balljoints were replaced quite recently with greasable moog units (much nicer than oem). so i doubt it's them. everything will get retightened after i cut off my tanabe brace and change out my LCA's. (long story there).
Old Jun 20, 2007 | 10:17 AM
DoC-JoneS's Avatar
wouldn't a C/V axle just get worse with speed? this seems to be almost entirely load based.
silas871
Apr 16, 2013 09:29 AM
maurob18a1
Jul 7, 2007 11:06 AM
Extreez
Mar 4, 2007 12:20 PM
Backk InTheDA
Aug 3, 2005 11:57 AM
