no spark 4th gen
well finished my h22 swap, everythings hooked up to my knowledge and the car wont start, no spark at all, using h23 dizzy with external coil, hooked up and everything, umm im getting a CEL but i dont know how to check the code, id search but search is down atm...someone help please
Modified by relited at 11:54 AM 6/17/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by relited »</TD></TR><TR><TD CLASS="quote">help please</TD></TR></TABLE>
Are you getting fuel?
If yes-
Check the coil. The FSM has the range of resistances allowed on it.
If it's good but no spark, could be distributor, igniter (inside dizzy).
If no-
You have bigger problems.
If yes-
If no-
the coil and the dizzy should be fine i took them off my h23 and there was no problem with them and that was like a week before i did teh swap..what do you mean biger problems? i got the h22 from hmotorsonline.com...ugh i just want this car to run lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by relited »</TD></TR><TR><TD CLASS="quote">im getting a CEL but i dont know how to check the code, id search but search is down atm...someone help please
Look behind the radio, there's a blue connector with two wires going into it. Jump the connector by inserting a wire or paperclip into the connector. Turn the key to ON, but do not start the car. Look at your dash, the CEL light should be flashing.
A long flash = 10
A short flash = 1
Count them up and there's your code. It will pause for like 2 seconds between codes if you have more than one code.
BTW, are you getting spark to the plugs? If not, try a different distributor. I'm willing to bet it's the ignitor inside the distributor. Mine went out on me randomly too.
A long flash = 10
A short flash = 1
What year is your car? If it is a 96 then you need to use the dizzy with the internal coil that came with the engine. Also check the ground that is screwed in right below the vtec solonoid. It might be a stretch and it is real easy to miss.
lol it was that ****** g101 ground on the thermostat sikb, i did miss it, and now it starts right up lol i feel like a noob, but yea thanks guys, this is my first swap ever and im glad i got it running
i forgot that too when i done my swap, its almost a guarantee that you will, even if you remember to do it!! Its dumb little things Honda done like that that **** you off but make it worthwhile in the end!
Car Tweaker
May 15, 2009 10:21 AM
