Question about gauge cluster
My car is a 1999 integra ls.
My gauge cluster is an ls one and i have a 97 gsr transmission.
My question is:
Will the rpm read incorrectly because of this? Reason I'm asking is because I've been searching around about gsr tranny specs. and found out that a gsr tranny going 80 mph on 5th gear should be at 4000rpm. But mine is at 3500 rpm at 80 mph.
P.S. I've tried to search.
My question is:
The transmission will not affect the tachometer operation. The relation between the speed and the RPM is determined by the gear ratios in the transmission. Check the calibration on your tach. Does the rev limiter intervene where it should? Most likely the transmission was not from a GSR, as an LS manual will operate at 3500 RPM in 5th gear at 80 mph. Sorry.
Damn if that is true then this is bull crap! got ripped off by a friend. ******* POS. the weird thing is my tranny code is y80 which is a gsr tranny code. but i got that code from a sticker that has a bar code on it thats on the tranny. they couldve just stuck it on there.
is there anywhere else on the tranny that has the tranny code on it? i want to have some way to prove that it isnt a gsr tranny so i can get my money back.
http://www.ff-squad.com/tech/temp/Bgears.htm
Sorry. If the VIN was on the transmission and it said DC2, then it is a GSR or ITR. (The VIN would differentiate ITR from GSR too.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/tech/temp/Bgears.htm
Sorry. If the VIN was on the transmission and it said DC2, then it is a GSR or ITR. (The VIN would differentiate ITR from GSR too.)</TD></TR></TABLE>
A lil bit confused.. so what does that mean?^
If I recall correctly, 1997 and newer transmissions were required to have the VIN on the transmission. So, it would say DC2/DB8 (GSR) or DC4/DB7 (LS). If the transmission has no VIN plate and is a 1997, it is most likely stolen. The Y80 should indicate a GSR or ITR transmission.
An easy way to check would be to monitor the RPM change beween gears. Even if the tachometer is off, the ratio should be correct.
RPM1/Ratio1=RPM2/Ratio2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">Another thing i forgot to mention. My car goes pass redline. is that normal without being chipped?</TD></TR></TABLE>
How much past redline? 100-200 RPM is normal for the fuel cutoff to engage.
thanks for all the helpful info dogginator
How much past redline? 100-200 RPM is normal for the fuel cutoff to engage.</TD></TR></TABLE>
as for the redline, it goes farther than 100-200. it goes i would say to nearly 8000. but i have never dared to push it to 8000.
i think 8000 is the redline. my buddy had a gsr and he would take it to 8100 or 8200 i think. im not sure but i think vtec hits at 4800. hopefully this will help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by little dx that could »</TD></TR><TR><TD CLASS="quote">i think 8000 is the redline. my buddy had a gsr and he would take it to 8100 or 8200 i think. im not sure but i think vtec hits at 4800. hopefully this will help</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">My car is a 1999 integra ls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 »</TD></TR><TR><TD CLASS="quote">do a test go 60mph in 5th gear and your rpm's should be at 3krpms then you know its a gsr trans if it goes to 4krpm in 5th gear at 60mph its a b16 </TD></TR></TABLE>
in 5th gear at 60 its going pretty much exactly 3000 rpm.
my motor is a jdm b20b
chassis is just an ls one.
i think the b20 redlines at 6200. i was looking at a crv and thats where the tac says it redlines. are going to do the ls/vtec because the stock b18 had more horse power or did the motor come with the car when you bought it? just curious what intake manifold is on it?
well i bought it from a friend when he put in the b20 motor and a "gsr" tranny. the intake manifold should be a stock b20 one. i was originally planning on going b20/vtec but its really not worth the money. just gona save money for other things in life.
im really pissed off. my friend would never ripp me off. i know cuz hes always hooking me up with parts. but the rpms just dont match up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">in 5th gear at 60 its going pretty much exactly 3000 rpm.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">But mine is at 3500 rpm at 80 mph.</TD></TR></TABLE>
If both of those statements are true, the tachometer is not responding linearly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">well i bought it from a friend when he put in the b20 motor and a "gsr" tranny. the intake manifold should be a stock b20 one. i was originally planning on going b20/vtec but its really not worth the money. just gona save money for other things in life.</TD></TR></TABLE>
well the stock manifold wouldnt fit thats why i asked. must be the ls manifold. better off with the stock b18 if your not going cr/vtec
well the stock manifold wouldnt fit thats why i asked. must be the ls manifold. better off with the stock b18 if your not going cr/vtec </TD></TR></TABLE>
i like the b20 torque. and i like the 2.0 liter engine.
i like the b20 torque. and i like the 2.0 liter engine.</TD></TR></TABLE>
just as long as your happy with what you got, thats what matters
igorka_91
May 4, 2010 08:14 PM
