New Radiator problem for crx!!!!!!!!
I got a 90 crx, I just put a new radiator in and nothings working!!!!!! Its not sending ant-freeze to the motor!!! Not sure of the problem. Can anyone help????
How will I go about doin that????? Cuz I put a new radiator in connected all the wires and the hoses, its not leaking any coolant its just not getting sucked into the hoses!!!!
Where the top hose connects to the motor there is a small thing that looks like a bolt with a hole in the top of it. Loosen that up and pour antifreeze in the radiator until it comes out of that hole. Then tighten it back up and fill the radiator to the top. Make sure there is antifreeze in the overflow tank too. Now start the car and let it run at an idle. Be sure you have the heater on so the water will flow through the heater core too. Watch the temp gauge to make sure it doesn't get too hot. after the radiator fan comes on you can shut the car off and let it cool down. After the car cools down, check to see if it needs anymore antifreeze.
Done
Done
milkwasabadidea
Jan 8, 2011 10:22 AM
Ek9_Cuhzz
12
Nov 3, 2010 02:35 PM
tinoeast14k
Jun 18, 2007 05:21 PM
