Alternator issues
Old Jun 17, 2007 | 06:36 AM
Boosted Chemist's Avatar
Default Alternator issues
At idle my car runs fine, but as soon as i rev the battery lgiht comes on. WTF? So i stop and go and this is constant. Get out the dvm and i have 13 volts at idle and the battery is fine, all is hooked up. Rev up the the car and im getting 17 volts @ 2k rpms. Im thinking this is an alternator issue. I have a autozone reman (2nd replacement) With only 10k miles on it.
Im getting sick of pulling these pos out and going to the zone. Can i rebuild this with new oem parts and have better luck?
Any other ideas? TIA
Old Jun 17, 2007 | 06:54 AM
rexracerboy's Avatar
Default Re: Alternator issues (Boosted Chemist)
Hmmmm...could be the alt regulator? Seems weird that you would have gotten two bad ones in a row...did they test it for you before selling it. I just did one for my g/fs civic, and asked them to test the reman one before I took it home. They ought to be able to at least tell you if it's functioning OK from the store. If it is, then you can start trouble shooting something else like bad/shorted wires.
BTW, are you blowing the alt fuse either under the dash or under the hood?
Old Jun 17, 2007 | 07:10 AM
Default Re: Alternator issues (rexracerboy)
Na no fuses nothing else, i checked the helms and all it says is dont let the voltage get over 18. My car was running way way rich 10-11 afrs at cruise, so maybe a influx of excess voltage would cause this?
Old Jun 17, 2007 | 07:49 PM
zerepdivad's Avatar
with a good alternator you should read 14.4 volts at idle.
Old Jun 18, 2007 | 04:01 AM
Default Re: (zerepdivad)
yeah went to the zone and the alternator was shot
Old Jun 18, 2007 | 03:28 PM
Default Re: (Boosted Chemist)
good thing they offer life time warranties huh? lol
Old Jun 18, 2007 | 03:37 PM
Default Re: (rexracerboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexracerboy &raquo;</TD></TR><TR><TD CLASS="quote">good thing they offer life time warranties huh? lol </TD></TR></TABLE>
Yeah really, they suck, i may just get a oem new honda instead of swapping these pos out ever year
Old Jun 18, 2007 | 03:48 PM
They prolly put them back on the shelf, and rotate them. lol
naw, seriously, so far I've had good luck with axles, atls, and misc. parts from autozone. Sounds like you are having some bad luck.
Old Jun 18, 2007 | 04:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexracerboy &raquo;</TD></TR><TR><TD CLASS="quote">They prolly put them back on the shelf, and rotate them. lol
naw, seriously, so far I've had good luck with axles, atls, and misc. parts from autozone. Sounds like you are having some bad luck.</TD></TR></TABLE>
I change axles more than i change oil, still lifetimes
(Im making a couple hp to the wheels)
Old Jun 18, 2007 | 07:09 PM
(Im making a couple hp to the wheels)</TD></TR></TABLE>
Ouch! I get to keep fixing things on my car that the last owner f-ed up, lol. Plus the tires I had a shop put on recently...the lugs were torqued down too tight and marred one of them so bad it won't come off normally, now I get to mess with that
Someday...I tell myself...someday I will get to do something fun, hehe.
But I digress....
MooreBoost
May 19, 2017 05:40 AM
SupraRXZ
Mar 20, 2007 07:52 AM
B2AMMO
Mar 9, 2004 07:59 AM
boonacka
Jan 27, 2003 01:24 PM
ck279
Oct 12, 2001 05:27 PM
