Aftermarket Headlights
Can you post tech specs and pics of your aftermarket headlights and also what website they were purchased from. Thnks
Harry
http://www.civicheaven.150m.com
Harry
CTR headlights, sorry no pic go to http://www.inlinefour.com. BTW what kind of car do you want headlights for? mines a 99 usdm si.
The lights i am after are on this car i also need to know if these are 1996-1998 lights and where are they available from thnks.
http://www.civicheaven.150m.com/1053.html
thats an aftermarket front end. probably beable to get it for 96-99
as for the lights, youcan do it your self by baking your lights for like 10 min at 200 degrees. pull them apart. sand, mask, paint. heat up the lights again in the oven, re-seal with the factory glue. then put a small amount of silcone on the seal just for safety. if you do a search in the appearance cosmetic section you can find some more detailed instructions.
