GC tophats w/ Full Coilovers (PIC, Omni, F2, Tein...)
Being that theses coilovers are somewhat similiar, would running GC tophats work on these? or is the shaft to small?
would the tophats cause any issues or implications to the suspension(s) mentioned in the title?
Not sure if ours will accept the GC tophats, but I can tell you that the GC tophats will not work the way they are intended to with our coilovers. Our wider shock body will not fit inside the top hat, and so will not allow for increased travel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance »</TD></TR><TR><TD CLASS="quote">Not sure if ours will accept the GC tophats, but I can tell you that the GC tophats will not work the way they are intended to with our coilovers. Our wider shock body will not fit inside the top hat, and so will not allow for increased travel.</TD></TR></TABLE>
nor do the extended top mounts you provide on your EF Kit....
