How To Get Clear Turn Signal Lenses
Old Jun 16, 2007 | 04:40 PM
prelude_93vtec's Avatar
Default How To Get Clear Turn Signal Lenses WRITE UP
Hey, i just got done with my tail lights and decided to do a write up. Its a little bit harder than it looks because the glue on these lights are a B!t(h. My purpose of doing this was to get rid of my old alteza lights and have a nice decent look. I was looking at the stock taillights and the thing that bothered me the most was the amber part. I was looking at some write ups and all of them showed the amber part gone and the bulb showing and i didnt like that. So i found a way to make a clear cover for it. Here are my steps.
1. Have your stock taillights ready and take off wiring harness ( 2 screws holding it in) and the gasket.
MAKE SURE NOT TO PUT WIRING HARNESS OR GASKET IN OVEN.
2. Preheat oven to 250-350 degrees. I put the taillights on a cookie sheet overlapped with foil so they dont get burnt.
3. Put them in the oven for about 3-5 minutes checking on them constantly.
4. Take a knife or prying tool and take off glass covor off the tail lights. ( this part takes a long time and its hard, but itll work.) the glue is still strong, but itll come off.
5. After glass is off, take end of screw driver and hit the amber cover that covers up the bulb from the inside. it should come off pretty easily.
Heres what you should end up with
Now here is the part that was the hardest for me.
I went to Home Depot and got an acrylic lightning panel sheet.
I traced the stock lens over the smooth side of the sheet and traced the shape. Then i started cutting it. It was real hard cutting it without getting cracks and stuff. Heres the result.
I placed them in and that part is done. The fitting is not good butit'll do. It might be loose but nothing will happen.
BTW. if you dont wanna make your own, i have extras. 6 bucks shipped.
Heres the result.
After that, put glass back on headlights. Just out them in the oven 250-350 degrees for about 3-5 minutes and push them back into place. Its pretty hard but if you push hard enough, itll go back in place. ( BE CAREFUL. THE GLASS GETS PRETTY HOT S O USE A CLOTH OR A COOKING MIT.
Heres how the final product should turn out.
Then, put the wiring harness and bulbs back in and the gasket back and there you have it, clear lenses.
Heres how they look on the car.
Enjoy!
Modified by prelude_93vtec at 10:31 AM 6/17/2007
Old Jun 16, 2007 | 04:49 PM
Default Re: How To Get Clear Turn Signal Lenses (prelude_93vtec)
And BTW I'm selling the old altezza ones. i out my own custom honda sign on the brake light cover. looks amazing at night. has a crack on the glass by the honda signs on both cuz of some honda haters poking at it. here are some pics.
give offers.
Old Jun 16, 2007 | 04:57 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">
give offers.</TD></TR></TABLE>
Give me $5 and I'll throw them away for you.
Old Jun 16, 2007 | 04:59 PM
Default Re: How To Get Clear Turn Signal Lenses (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Give me $5 and I'll throw them away for you.</TD></TR></TABLE>
lol thats why i got the stock one sback on. these dont look good.
Old Jun 16, 2007 | 11:17 PM
russlan44's Avatar
i did my recently but i ddint put the acrylic lightning panel sheet insted of the yellow peice i just put them together and its looks ok, got pulled over cuz my turning signal is to bright the cop told me to get a yellow bulb and ill be fine so i did that
Old Jun 17, 2007 | 09:26 AM
Default Re: How To Get Clear Turn Signal Lenses (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">i did my recently but i ddint put the acrylic lightning panel sheet insted of the yellow peice i just put them together and its looks ok, got pulled over cuz my turning signal is to bright the cop told me to get a yellow bulb and ill be fine so i did that</TD></TR></TABLE>
the acryllic sheet is perfect for it. i gives a nice stock look yet an aftermarket look. its still pretty bright but not as bright as not having the acrylic sheet on
Old Jun 17, 2007 | 04:52 PM
Default Re: How To Get Clear Turn Signal Lenses WRITE UP (prelude_93vtec)
hey i didnt wanna start a new thready so im jus gunna ask here. what can i use to make my taillights black? i heard of this thing called nite shade. does that work good?
Old Jun 17, 2007 | 04:57 PM
mattsnooz's Avatar
hey good job man. looks very clean!
can you make me an electric supercharger too? that can maintain 5-6psi and flow around 400-500cfm but still only run off my one 12v 750 amp battery?
Old Jun 17, 2007 | 07:00 PM
Default Re: How To Get Clear Turn Signal Lenses WRITE UP (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">hey good job man. looks very clean!
sure ill start on that rite now
ender_ej1
11
Jun 28, 2007 11:12 AM
97lsvtec
Acura TSX
16
Apr 16, 2007 02:03 PM
accordmaniac23
Feb 10, 2007 05:05 PM
ridiculous
Oct 23, 2002 09:51 PM
Digitalcivic
Aug 6, 2002 12:59 AM
