After rebuilding my motor - compression is 275 PSI across all four cylinders
Well, after rebuilding the bottom end, and getting my top end rebuilt by JUN, my motor is finally back in the car. Compression tested at 275 PSI on all four cylinders. I gotta break the new bearings and rings in for 1600 km, and then its dyno time.
[Modified by canuck-mx6, 9:08 PM 6/5/2002]
ewww altezzas... nice dynamic compression though.
People have accused me of being a ricer because I have altezzas, I will be swapping them back to all red 98+ tail lights.
how does that compare to, say, a stock ITR motor?
Nice looking Integra.
Question - What's the purpose of having large/heavy brake rotors when the brake pads contact only about half of the rotor? Notice much of the rotor near the center is bronze color while the outside has been discolored by the brake pad contact.
http://members.rogers.com/canuck-mx6...A_wheels_1.jpg
thats STATIC compression
Static compression simply put is calculated compression ratio.
Dynamic compression is compression ratio while the engine is running.
A compression test doesnt really tell you much other than the rings are sealing
well. It cannot really give a good estimate on compression ratio though
CR is one of the factors that affects it.
So in essence both our answers were wrong.
.....this begs the question of what can determine CR on a motor which has been rebuilt and possibly had the head milled or block "cleaned?"
[Modified by Black R, 4:52 PM 6/5/2002]
Here is the pic
[Modified by canuck-mx6, 10:10 PM 6/5/2002]
Nice looking car.
Did you get the wilwood caliper yourself or was it part of a kit? Fastbrakes? or Just the wiwoos kit?
Thats on a GSR Gead right? I have a b16 head on a b18c1 block with ctr pistons and im hitting 300 psi in all cylinders,
HondaEF
Sep 14, 2005 10:56 PM
siis2fast
Jun 16, 2003 11:09 AM
