civic 90 put one piece headlight
well, anyways how would i go on putting one peice headlights on? i got the headlight but it seem that i would need to alter the body frame. do i need to do that or do i just buy the fenders and the hood?
do you have a crx? one piece headlights come from a non-usdm 4 door ef. they ARE different.
if you bought an after market one then i would assume they should bolt right in.(considering that you would order it if it said for crx)
fabrication. you will probably be the FIRST to do it. IF there is someone who has done it. You will probably use
http://www.google.com
http://www.yahoo.com
http://www.excite.com
good luck to you.
good luck to you.
