Car wont start with motorola 2.5 map sensor
Old Jun 16, 2007 | 12:12 PM
RS DC4 94's Avatar
Default Car wont start with motorola 2.5 map sensor
as title states. 94 GSR obd1 wiring harness with motorola 2.5 map sensor spliced in before connector. using hondata s300 i went to -->"Map" tab -->"Motorola 2.5" from drop down menu. is there something im missing? no CEL either.
Old Jun 17, 2007 | 09:02 AM
RS DC4 94's Avatar
Default Re: Car wont start with motorola 2.5 map sensor (RS DC4 94)
bump
Old Jun 17, 2007 | 03:30 PM
RS DC4 94's Avatar
anyone?
Old Jun 18, 2007 | 10:26 AM
BEST1TUNING.COM's Avatar
Well what is the complete setup?
Old Jun 18, 2007 | 05:13 PM
RS DC4 94's Avatar
Default Re: Car wont start with motorola 2.5 map sensor (BEST1TUNING.COM)
-JDM Sir-G B18C Complete Engine
-JDM LSD Transmission
-81.50 Bore/Hone
-Wiseco Pistons
-Eagle Rods
-ACL Bearings
-ARP Headstuds
-Cometic Headgasket
-PeakBoost Ramhorn Manifold
-Garrett T3/T04E Turbo
-Precsion Intercooler
-Tial Wastegate
-Tial Blow Off Vavle
-P28 ECU w/Hondata S300
-RC Injectors
-AEM Fuel Rail
-Edelbrock 65mm Throttle body
-MSD Plug wires
-ACT 8lb. Flywheel
-ACT Pressure Plate
-ACT 6 Puck Disc
-Skunk 2 Intake Manifold
-Skunk 2 Adj. Cam Gears
-Hondata Intake Manifold Gasket
Starts and runs perfect. until i wired up the map sensor....wouldnt even start. when into hondata and changed the map to motorola 2.5 and uploaded it too.
-Where is everyone else pulling there vaccum source for it?
Old Jun 19, 2007 | 09:37 PM
mtber's Avatar
Connect to your s300 unit and start datalogging.
Check if you are getting correct readings versus the readings on a vacuum/boost gauge.
This will inform you if your map sensor is wired incorrectly or damaged.
Old Jun 20, 2007 | 05:04 PM
RS DC4 94's Avatar
Default Re: Car wont start with motorola 2.5 map sensor (mtber)
cant. car wont even start with it installed
Old Jun 20, 2007 | 05:56 PM
Jim Truett's Avatar
You don't need it to start. Compare the mBar reading of the 2.5 bar to the stock sensor with the ignition on, engine off.
honda_hackett
Engine Management and Tuning
Aug 17, 2009 05:28 AM
pingaturbo
Jun 6, 2005 10:52 AM
vti2
May 5, 2004 08:00 AM
1.8T_EG
Feb 14, 2003 10:12 AM
