OIL PAN! in need of help!
Old Jun 16, 2007 | 10:57 AM
Enzo757's Avatar
Default OIL PAN! in need of help!
I recently found out that my oil pan drain plug was stripped out from the previous owner of my 1996 Honda Civic EX Vtec. I was wondering if it were at any way possible to weld the stripped drain plug whole shut and tap a new one right next to it to save the pan and save some money in buying a new one! Please any help is appreciated! thanks!
Old Jun 16, 2007 | 11:04 AM
pdiggitydogg's Avatar
You can just attach a new nut, in place of the old too
m14 x 1.5
Old Jun 16, 2007 | 11:19 AM
ak_teg92's Avatar
Default Re: OIL PAN! in need of help! (Enzo757)
new oil pan plug? is the hole stripped to or just the plug
Old Jun 16, 2007 | 11:47 AM
Enzo757's Avatar
Default Re: OIL PAN! in need of help! (ak_civic)
The hole is stripped not the plug, and I don't want to buy a new one so is there a way to fix it?
Old Jun 16, 2007 | 11:55 AM
hall97civic's Avatar
just weld a nut on it, but do a good job so it doesn't leak. You could fill the hole too if you have a wire welder. But it will drill like a sob. Welds are very hard man, just weld a new nut.
Old Jun 16, 2007 | 11:58 AM
Enzo757's Avatar
Default Re: OIL PAN! in need of help! (hall97civic)
well i can get it welded properly but how do i then go about tapping a new hole for the the new drain plug?
Old Jun 16, 2007 | 11:59 AM
Default Re: (pdiggitydogg)
uhh...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">You can just attach a new nut, in place of the old too
m14 x 1.5</TD></TR></TABLE>
fill the old one, drill a new hole, weld a new nut on
Was what I said unclear?
Old Jun 16, 2007 | 12:01 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo757 &raquo;</TD></TR><TR><TD CLASS="quote">well i can get it welded properly but how do i then go about tapping a new hole for the the new drain plug?</TD></TR></TABLE>
dude, that's to much work. go to the parts store, there is a special plug just for situations like this. works great, i used it on my old d15.
Enzo757's Avatar
lol it kind of was unclear i didn't understand it sorry I honestly just wanted to know if it could be done, if it was even possible. But what tap do i need to buy for the new hole
Old Jun 16, 2007 | 12:03 PM
You dont tap a nut thats already threaded...just drill a 14mm hole
I really dont like those repair plugs. Ive had two fail
Old Jun 16, 2007 | 12:05 PM
Enzo757's Avatar
lol omg. Ok i need to tap the<U> PAN</U> so i can thread a bolt into that so i can make a new drain plug that works.
Modified by Enzo757 at 1:22 PM 6/16/2007
Old Jun 16, 2007 | 12:15 PM
philosofy1's Avatar
Default Re: (Enzo757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo757 &raquo;</TD></TR><TR><TD CLASS="quote">lol omg. Ok i need to tap the<U> PAN</U> so i can thread a bolt into that so i can make a new drain plug that works.</TD></TR></TABLE>
this is the simplest solution to your problem,
http://www.partsamerica.com/Pr...=3126
if you don't want to use this then do it the right way and replace your pan.
Old Jun 16, 2007 | 12:31 PM
Cant you read?
I have repeated myself like 4 times now
You need to weld on a new nut! You cannot tap the pan - it will rip out.
Even if you wanted to do that, thinking it would work correctly, I told you the thread size/pitch right off the bat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">m14 x 1.5</TD></TR></TABLE>
You dont seem capable enough to fix this the right way w/o changing the pan
Go to the parts store and get what ed keeps suggesting instead<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">this is the simplest solution to your problem,
(just cant help some people)
Leb_CRX
35
Jul 16, 2007 05:34 PM
1EGdude
Jan 18, 2007 04:51 PM
Ls InTeGrA RaCeR
Jan 10, 2006 12:21 PM
mitch3814
Apr 5, 2005 06:37 PM
SpeedMonkeyRacing
Aug 7, 2003 07:07 AM
