91 CRX HF WITH DX HUBS.....WHICH IS BEST BRAKE UPGRADE FOR B16???
Old Jun 16, 2007 | 10:37 AM
alscrx's Avatar
Default 91 CRX HF WITH DX HUBS.....WHICH IS BEST BRAKE UPGRADE FOR B16???
HEY GUYS, I HAVE A 91 CRX HF WITH A JDM B16A. OF COURSE I HAD TO CHANGE HUBS TO FIT NEW AXLES SO I GOT A PAIR FROM A 88 CRX DX. I WANT TO DO A BRAKE UPGRADE. WHAT SHOULD I GO WITH CONSIDERING FITMENT ON THE 88 CRX DX HUBS?????? ANY SUGGESTIONS WOULD HELP
Old Jun 16, 2007 | 12:14 PM
1 Fly SI's Avatar
Default Re: 91 CRX HF WITH DX HUBS.....WHICH IS BEST BRAKE UPGRADE FOR B16??? (alscrx)
You could put integra knuckles on it.
Old Jun 16, 2007 | 12:24 PM
Super Chicken's Avatar
The best and cheapest way to go is good rotors (Brembo blanks not drillled or slotted) and some good pads like EBC green stuff or Hawk HPS, but the most important thing is good tires because if you put big or upgraded brakes on and don't have the ability to stick to the road then it doesn't matter whether you have STD brakes or NSX brakes if the car just slides then you won't stop any faster!!!!
Old Jun 16, 2007 | 02:00 PM
alscrx's Avatar
Default Re: 91 CRX HF WITH DX HUBS.....WHICH IS BEST BRAKE UPGRADE FOR B16??? (Super Chicken)
I heard bad stuff with integra knuckles so i am stayin away from those,,,, And i really wanted go with bigger rotors and calipers. Rather than stock 88 dx calipers and pads
Old Jun 16, 2007 | 02:18 PM
HonDelso's Avatar
I use 90-91 4 door ex knuckles. I had them from my 4 door ex shell(someone killed it). then i got my 88 crx dx shell. so what the hay right?
10 inch rotors instead of the 9 inch. from 1 ef chassis to another.
I don't know what bad stuff you heard about integra knuckles. if they were so bad then why do they put them in integras?
It does somewhat effect you suspension, but not to a major degree that would affect it undrivable, or considerably damaging to your vehicle, and it's something an alignment could fix.
regardless do your alignment when you change stuff like the above there is no way a person can put it perfectly straight. it may look straight though.
Old Jun 16, 2007 | 02:41 PM
alscrx's Avatar
Default Re: (HonDelso)
What i was saying is that those knuckles on a crx mess with the camber. There was a writeup on here i am sure that does the comparison of knuckles. The guy took measurments of the DA knuckles, SIR knuckle, CRX SI AND DX knuckles,etc. They do not recommend those knuckles so i stood clear of any problems. Yeah your right, nomatter what you need an alignment. But if the angle of the wheel is off too much then you'll need a camber kit. Its not worth it. I Just got another crx knuckle instead. Sometimes things can't be fixed with an alignment.
I would get the ex knuckles but they are hard to come by now. I couldn't find them. So what can i use workin with what i have, The 88 crx knuckles and hubs????????????????
Old Jun 16, 2007 | 02:59 PM
HonDelso's Avatar
putting on DA/DC knuckles won't affect your alignment to where you would need a camber kit. unless the knuckles you bought are bent. IT will however depend on your chassis. for example it's been into an accident, or some mean hitting/hopping off curbs. My friend's crx drives fine with DC knuckles and no camber kit, just got his alignment done.
Old Jun 16, 2007 | 03:05 PM
HonDelso's Avatar
you could go with:
90-91 ex knuckles
Corrado 11 inch rotors (4x100) (not 100% sure waiting for a friend to lend me his corado rotors seems easier than redrilling prelude rotors)
DA brakes
Old Jun 16, 2007 | 03:09 PM
1clnef9's Avatar
you are wrong about the dc knucks you have to use da knuckles they work perfect without a camber kit the dc knuckles will give you positive camber
Old Jun 16, 2007 | 03:23 PM
alscrx's Avatar
Default Re: (1clnef9)
Then the dc was what i was reading about!!!
Old Jun 16, 2007 | 09:07 PM
MOE@Hyper16Valve's Avatar
Default Re: (alscrx)
You should check out FASTBRAKES.com they sell all sorts of brakes kits to try out, The only problem i see with some of there kits is you might have to change rim size for some to fit but now a days how's or stock rims...
Old Jun 17, 2007 | 05:15 AM
CRX Toad's Avatar
This has been covered many times please look in the FAQ
https://honda-tech.com/zerothread/1508680
ceyazzie
24
Nov 25, 2007 05:54 AM
doublethink
11
May 30, 2007 01:30 PM
zerogravitycrx
Mar 23, 2005 11:46 PM
AgentJam
13
Dec 1, 2004 10:52 AM
gringo7718
Sep 24, 2004 09:12 AM
