Code Error 9
Old Jun 16, 2007 | 10:30 AM
louevilhatch's Avatar
Default Code Error 9
My ECU is throwing a code 9 which is #1 cylinder position. How do I fix this? I have a b16a if you need to know.
Old Jun 16, 2007 | 10:34 AM
mr.speaker's Avatar
Default Re: Code Error 9 (louevilhatch)
replace distributor,sorry.
Old Jun 16, 2007 | 10:43 AM
its a brand new distributor.
Old Jun 16, 2007 | 10:50 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by louevilhatch &raquo;</TD></TR><TR><TD CLASS="quote">its a brand new distributor.</TD></TR></TABLE>
I don't know what to tell you then..Because that sensor is inside the distributor,and what happens 99% of time is, the distributor bearing starts going and heats up all the sensors inside,causing them to fail,causing the code.
Have you tried re-setting the ecu ?
Old Jun 16, 2007 | 02:02 PM
janz3n's Avatar
Default Re: Code Error 9 (mr.speaker)
iv read people getting this code with brand new distributors before and they had to replace them.
Old Jun 16, 2007 | 02:07 PM
EF2_Sedan88's Avatar
Default Re: Code Error 9 (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">iv read people getting this code with brand new distributors before and they had to replace them.</TD></TR></TABLE>
that happend to one of my friends car and then after replacing the brand new dizzy the code went away
Old Jun 16, 2007 | 04:28 PM
gnar kill's Avatar
Default Re: Code Error 9 (EF288Gsr)
I has this problem but it turned out to be a wiring issue......the helms manual shows you how to check if it is bad or not I remember testing for the ohms of impedence across some of the terminals. It is cheaper to check before you buy a dizzy
Old Jun 16, 2007 | 05:32 PM
Default Re: Code Error 9 (gnar kill)
the car starts and then it just kills itself....so more than likely its going to be the distributor, right?
Old Jun 16, 2007 | 08:28 PM
dohczcrex's Avatar
Had a similiar problem on my a Dohc zc turned out to be the engine timing the car would warm up alittle then just die
dank24
Jun 12, 2006 07:17 AM
shocker
Oct 13, 2005 01:19 PM
zccr-xsi
Jun 5, 2005 03:49 PM
Rickcrx
Aug 11, 2004 01:06 PM
Ekay Jay
18
Jun 24, 2004 10:06 PM
