b18 into eg
Old Jun 16, 2007 | 08:33 AM
heavyhittersclub's Avatar
Default b18 into eg
Ive Got a 93 hatch automatic
Is it way easier to get a whole standard car to do the swap? I can Buy a 92 standard teg cheap
will the entire car give me everything i need with exception of the rad hoses
Old Jun 16, 2007 | 09:02 AM
Slopoke's Avatar
Default Re: b18 into eg (heavyhittersclub)
No. A '92 integra has a cable transmission.
It wont give you many of the parts you need for the auto to manual conversion, plus it will require that you buy more parts than you would need to if you just got the correct trans/linkage/pedal assembly.
Old Jun 16, 2007 | 11:10 AM
Default Re: b18 into eg (Slopoke)
but wont the standard car give me a cable shifter assembly? so you can hook the cable shift assembly off the integra and install it on the eg?
Old Jun 16, 2007 | 11:16 AM
Slopoke's Avatar
Manual transmission civics and integras use rod shift linkage, not cable.
The cable is used to disengage the clutch.
Your civic is designed to use a hydraulic clutch system, not a cable.
You cant use the cable in the civic.
Also the pedal assembly is not the same and the engine mounts are different.
Its not worth all the extra trouble.
Just get the correct stuff.
Nathaniel Corum
Nov 2, 2014 01:52 PM
f@sth@tch89
Transmission & Drivetrain
Jan 25, 2011 08:10 AM
H23_del_soul
Aug 24, 2010 09:19 PM
m3guy87
Nov 21, 2001 10:03 AM
