91 CRX ZC Swap problem (Crank Position)
Old Jun 16, 2007 | 08:14 AM
Shingpumps's Avatar
Default 91 CRX ZC Swap problem (Crank Position)
Swaped SOHC zc moter with modified Odb0 harness, stock ecu. Car cranks up but dies when gas givin. Throws error CPS. And o2. theres no o2 sensor. What first?
Old Jun 16, 2007 | 09:25 AM
jlicrx's Avatar
Default Re: 91 CRX ZC Swap problem (Shingpumps)
code 9 means there is a problem with the distributor or with the distributor wiring - not related, but fix the O2
Old Jun 16, 2007 | 10:47 AM
ludesrv's Avatar
Was the car an Si, cause if it was it's a straight engine swap. You should be throwing codes.
If it was a Dx, and you did the MPFI swap, and look into it again. You must of crossed a wire for that sensor.
Old Jun 18, 2007 | 02:15 PM
Shingpumps's Avatar
It's a hf?
Old Jun 20, 2007 | 08:37 AM
IT GUY's Avatar
Default Re: (Shingpumps)
what distributor are you using?
Old Jun 27, 2007 | 02:43 PM
Shingpumps's Avatar
I used a dist. off of a 95 DX.
Old Jun 27, 2007 | 03:31 PM
MagnaniEG6's Avatar
Wiring is wrong did you wire it like this?
Old Jun 27, 2007 | 05:42 PM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shingpumps &raquo;</TD></TR><TR><TD CLASS="quote">I used a dist. off of a 95 DX. </TD></TR></TABLE>
The 95 DX distributer is OBD1 and will not work with an OBD0 ECU. You either have to convert the car to OBD1 or get an OBD0 distributer.
Old Jun 28, 2007 | 07:09 AM
MagnaniEG6's Avatar
Default Re: (Sikocivic)
are you using an OBD1 ZC motor?
Old Jun 28, 2007 | 08:10 AM
SIred91's Avatar
Rainman
Default Re: (MagnaniEG6)
If its an HF and its an0BD0 zc, then its a straight up swap.....no changes from an hf or si
Why is the harness modified?
Old Jun 28, 2007 | 11:04 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">If its an HF and its an0BD0 zc, then its a straight up swap.....no changes from an hf or si
Why is the harness modified?</TD></TR></TABLE>
Because he hacked an OBD1 distributor into there. This is a problem unless the motor is OBD1.
Efsdn89
Sep 27, 2018 08:34 PM
altfuelneeded
25
Sep 30, 2011 10:08 AM
remoer
Oct 29, 2008 10:01 AM
idontcare
20
Dec 7, 2003 12:53 PM
the DR.
Jul 1, 2002 06:14 AM
