Any tricks to bleeding the clutch?
Old Jun 16, 2007 | 08:02 AM
gulfview's Avatar
Default Any tricks to bleeding the clutch?
I replaced the master and slave cylinders for the clutch, connceted all the lines, poured brake fluid into the reservoir, attached a bleeder line to the open bleeder valve on the slave, and pumped the clutch -- but could not get any pressure.
Are there any steps or tricks that I am missing? (Is trapped air the problem?)
Please respond.
Old Jun 16, 2007 | 08:36 AM
98savage's Avatar
Default Re: Any tricks to bleeding the clutch? (gulfview)
The reason there is no pressure is because there is air in the line....when you put the hose onto the bleeder screw, you put the open end of the hose into a small container of brake fluid. You'll notice bubbles and such because of the air....and after a bit, the brake fluid will come out and you close the bleeder screw and you're set.
What size of hose did you use?
Old Jun 16, 2007 | 09:44 AM
gulfview's Avatar
Default Re: Any tricks to bleeding the clutch? (98savage)
Thanks for the help.
The setup with bleeder hose and brake fluid bottle was all in place. I just had to follow the "keep on pumping, honey," advice.
Problem solved.
killa31
Jul 10, 2018 05:59 PM
niceprelude
Jun 2, 2011 02:50 PM
TravisCadello
Oct 29, 2008 07:12 AM
Luchini
Oct 16, 2005 06:06 PM
Shotman
Jan 12, 2005 05:48 PM
