cam and crank oil seal replacememnt, need help asap!
ok, I'm doing my timing belt, water pump, etc. right now and I'm at the point where I need to replace the oil seals on the camshaft and crankshaft. Someone said before to use a small screw driver to pull it out but I honestly don't see how I can do that. Can anyone give me some quick tips on how to get those seals out?
Your help is appreciated, thanks.
You can use a sharp pick, but be sure not to score the metal around the seals. Stab the seal right in the middle (softest part/all rubber) and pull it out. I think I even used a small screw once.
so just use a small pick, poke the seal right in the middle (between cam and head jernal (sp?)) and pull it out? Thats it?
yep, thanks. I got that done, it was easier than I figured it would be.
now I have another issue
https://honda-tech.com/zerothread/2015875
TOO MUCH TORQUE
Feb 13, 2015 06:13 PM
NeverOut215
Sep 30, 2011 08:56 AM
pityocamptes
Mar 16, 2010 03:34 PM
Nathan007
Jun 10, 2009 03:20 PM
