Prelude sunroof
get yourself a 97-01 glass sunroof. you will never have to worry about rust.
this is what you need:
97 up prelude glass assembly
97 up brackets that hold the glass
about 10 small washers
remove your interior trim piece to expose the 8 10mm nuts holding the panel in
remove the old brackets, these will be held on with small phillips head screws
you will need to remove the entire headliner.
after the new glass is reinstalled with new brackets, you will see it sits too high.
you will need to probably add shims to the front 4 bolts that hold the whole assembly to the roof of the car.
Depending on your particular car, you may need more shims.
add you shims before you replace the interior,( I learned the hard way)
enjoy your new rust free panael!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein »</TD></TR><TR><TD CLASS="quote">that's actually a really good recourse
its just heavier</TD></TR></TABLE>
It's only ~5 pounds heavier.
If you never use the sun roof, you can always buy a plug for it, drops a substantial amount of weight.
Stealth_Ek9
Jan 7, 2007 11:53 AM
