question about twm 50mm itb's
Can they work with a mugen p28 chip, apexi and 440cc injectors?
specs:
b18a1 block sleeved and bored to 84mm
b18a1 stock crank
b16 head ported & polished
probe I beam rods
13.2:1 wiseco pistons
jun3 cams
ferrea outer springs & stock inner springs
ferrea retainers
rev flat stainless steel valves
stock b16 flywheel
4 puc clutchnet disc
act pressure plate
walbro 255 fuel pump
venom cam gears
unortodox crank pulley
balanced
etc.
with a skunk2 im, holley 68mm tb, 345cc injectors and custom 3" cai, made 226.9whp & 150.4wtq and 12.3@ 106.8mph
specs:
b18a1 stock crank
probe I beam rods
jun3 cams
ferrea retainers
stock b16 flywheel
act pressure plate
venom cam gears
balanced
etc.
hondata, crome, or any other tuning software that allows you to use tps input only or a map/tps combination will make the engine run much better than a simple vafc.
or are you talking about a powerFC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18master »</TD></TR><TR><TD CLASS="quote">It works really nice I just use 3 gal. of 93 octane fuel for each gal. of vp c-12 to stop knocking at low rpms.</TD></TR></TABLE>
or you could use an actual tuning program and be perfectly fine with regular 93. hell you might even be able to squeeze out a few more hp by tuning the fuel and ignition maps seperately.
I already sold the complete intake system, and finished port matching the new itb's.
I will install them tomorrow and will try to tune them a little bit so I can get to the dyno on monday. I have a friend that knows how to work with crome, hope he could go with me...
if you havent already, you might want to think about tapping the runners and running a vac line to a single source for a better signal. there's a couple guys in the all motor forum with twm's that have done this.
