Fixing distributor plug on 99 EX harness for 96 ITR swap
If you still have the dizzy plug from your D16 dizzy, you can make it work. You will use this plug and put it in the 96 dizzy. Disregard the Blue (engine speed output) wire coming from the dizzy. I made it work with by 99 B18B (OBD2A) in a 99EX.
Not home right now, have the link for the HT link for wire pinouts in my desktop. You can also search my username for a response i made to another HT member that had the same problem. GL
so preatty much color by color right does any one have digrams for IACV trick and 3wire to 2 wire knock sensor and all of this will be going to a od2b y7 harnes and the motor is a 97ITR its going to be runing a
P28 Chipd
P28 Chipd
VI Boost
Feb 24, 2012 06:56 PM
strider380
Nov 12, 2010 08:53 PM
NathanMorris
Jun 8, 2007 08:00 AM
