96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz.
Old Jun 15, 2007 | 01:33 PM
greynolds2007's Avatar
Default 96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz.
HEY I GOT 96 HONDA CIVIC WITH A 99 SI B16 ENGINE AND I BYE THE JUMPER OBD2 TO OBD1 CONVERSION I WANNA KNOW WHAT ECU I HAVE TO PUT ,A P28 SHIP OR P30 BECAUSE I PUT A REGULAR P28 AND THAT CAR DON'T GOINNG NO WERE.
Old Jun 15, 2007 | 01:41 PM
B18CivicEJ8's Avatar
Default Re: 96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz. (greynolds2007)
Have you tried getting a OBD2a to OBD2b jumper harness and putting on the stock Si ecu in to see if it runs?
Old Jun 15, 2007 | 01:45 PM
Default Re: 96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz. (B18CivicEJ8)
no
Old Jun 15, 2007 | 01:48 PM
Padawan's Avatar
Darth ModerVader
If you want to run the P28, you'll need to chip it and run the correct B16A base map, or have it tuned.
Old Jun 18, 2007 | 03:09 PM
Old Jun 18, 2007 | 03:44 PM
Padawan's Avatar
Darth ModerVader
You've be given the answer. Please stop re-posting the same question, and please stop typing in all caps.
Old Jun 18, 2007 | 03:50 PM
Default Re: 96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz. (Padawan)
soo what havd to do , buy a p28 ship or the jumper ob2a to ob2b ?
Old Jun 18, 2007 | 03:56 PM
Padawan's Avatar
Darth ModerVader
Either run the Si ECU (P2T) or use a conversion harness to run a chipped P28 with the proper maps.
Old Jun 18, 2007 | 04:05 PM
EE_Chris's Avatar
What you NEED to do is get a 96-98 Ex, or the original, harness back in there and modify to suit. If you want to run an OBD2a-OBD2b conversion harness so you can run the P2T ECU, then do that. But don't run the Si harness in your 96 Civic.
gitarman2
13
Jun 14, 2013 07:07 PM
bOOsT-FeIn
May 1, 2011 08:35 PM
ej8ster96
Jun 23, 2009 07:57 AM
Azxster
Sep 14, 2007 07:40 AM
EJ8FERIO
Aug 22, 2007 07:38 PM
