my new teggie
Guest
Posts: n/a
just got the rebuild complete, started at lunch time on monday with a bare block, had it on the road at lunchtime on tuesday, yep, that's right, and yes i pulled a hell of an all nighter...... notice anything weird about that engine???
Guest
Posts: n/a
ok, i know, the engine bay needs a little attention......
"Sam" is me, i used my work shirt to hold the power steering fluid in, i was going to put it back in, but decided it didn't matter, so now all i have to do is pull the lines...... fun fun
the missing throttle cable bolt is because the LS bracket holes didn't mount up to the Si intake manifold, but i am getting an ITR manifold, so maybe those will match up, if not i guess i will have to buy one
the engine alone is very very strong. with the Si pistons it yields approx 11.3:1 compression, probably a little more because the head has been resurfaced, i haven't had VTEC engage yet, because my ECU that i had wouldn't cooperate with the engine (chipped P28), so i'm rockin the the LS ECU for now, my TPS sensor was broken too, so i had to borrow a TB of an ITR swap that's sitting in my shop, i think i'll have to buy one for myself, it's GREAT
the E30 in the back ground is MINE, i love that car, i never drive it anymore, but can't bring myself to get rid of it, so it just sits most of the time, it needs some body work, but other than that it's excellent
[Modified by LUDE-a-cris, 4:05 AM 6/6/2002]
Guest
Posts: n/a
95 LS block, B18B1
NEW LS connecting rods
ARP rod bolts
NEW 99-00 Si pistons
NEW Si Rings
all new rod and main bearings
NEW GS-R oil pump
LS water pump
LS headgasket
LS timing belt
Complete JDM B16 head
99-00 Si Intake manifold
ITR Throttle Body
GS-R tranny
LS Injectors
Si Fuel Rail
NO A/C
NO power steering
ECU has yet to be determined, the one i had didn't work properly, currently rockin the LS ecu
kind of defeats the purpose huh
ARP rod bolts
NEW Si Rings
NEW GS-R oil pump
LS water pump
LS headgasket
LS timing belt
ITR Throttle Body
GS-R tranny
LS Injectors
Si Fuel Rail
NO A/C
NO power steering
Dude, looks like someone keyed it on the left side, then I'm guessing they spun it and hit a bridge w/ the front end
You made my old car look pretty good, i knew you'd use that blue hosing
you've slaved like a bitch on that and you deserve a few
s for it, i think i deserve a few too, i told you to torch that head bolt, LMAO.We'll run as soon as i get my next car, i think 1 BAR is fair?
then this
