ITR Motor in civ. hatch, Axle question
Old Jun 15, 2007 | 12:37 PM
IIXtremeHansen's Avatar
Default ITR Motor in civ. hatch, Axle question
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
what does that mean? lets say its going in a 97 dx hatch. axle bolt wont fit or what?
Old Jun 15, 2007 | 12:51 PM
b_serious's Avatar
Default Re: ITR Motor in civ. hatch, Axle question (Dickies_N_FlipFlops)
i dont think the stock axels will slide into the tranny or if useing the R axles they wont slide into your HUB
Old Jun 15, 2007 | 12:59 PM
Default Re: ITR Motor in civ. hatch, Axle question (b_serious)
so hows will i make it work?buyls,si any b series just not type r for it to work?
Old Jun 15, 2007 | 01:02 PM
b_serious's Avatar
im not sure, just guessing but maybe hybid axle half gsr/half type R? never had to deal with this so don't take my information to be 100% correct
Old Jun 15, 2007 | 01:05 PM
hmm ive always thought it swap in no problem. ls,si, axles boom its in, but type r huh. what you think you gotta upgrade the hub or something?
Old Jun 15, 2007 | 01:13 PM
Padawan's Avatar
Darth ModerVader
The original statement is referring to the fact that if you're running a JDM ITR suspension, you'll have to use the 36mm JDM ITR axles to fit the JDM ITR hubs.
If you're simply doing an engine swap and aren't using the JDM ITR suspension, you can use standard 32mm B-series axles.
Old Jun 15, 2007 | 01:14 PM
after nine30's Avatar
From: Dont you wanna know, California, United States
hmm all i have to say is you are gonna love ur car when u get it running,, me having the same car with the same engine,, u made a good choice for a engine
Old Jun 15, 2007 | 01:17 PM
Default Re: ITR Motor in civ. hatch, Axle question (Padawan)
oh yeah? i knew i was right, but the itr suspension thats new to me, thanks man
Old Jun 15, 2007 | 03:15 PM
yeah well i had my car done by One6 so i really cant tell you whats up with your suspension
Old Jun 15, 2007 | 03:16 PM
BlueIntegraBoy's Avatar
Stock suspension = any 94-01 Integra, 99-00 Civic Si, or 94-97 Del Sol VTEC axles will work
Old Jun 16, 2007 | 05:25 PM
Default Re: ITR Motor in civ. hatch, Axle question (BlueIntegraBoy)
what if i upgrade to itr 5 lug , how will the axles work?
Old Jun 16, 2007 | 06:42 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_N_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">what if i upgrade to itr 5 lug , how will the axles work?</TD></TR></TABLE>
The same, just depends on the hub/spline at end.
Old Jun 16, 2007 | 07:49 PM
elmo908's Avatar
you could use a different tranny that uses the right spline for your hub, but then it wouldn't be a proper type r swap.
emaka9
Feb 6, 2009 05:57 PM
_HANS
Oct 7, 2005 04:03 AM
CivicESi
Sep 27, 2004 07:53 AM
STN_Pat
Sep 14, 2004 12:19 PM
Nameless RB26
Sep 12, 2002 06:17 PM
