Front bumper for BIG intercooler.
Old Jun 15, 2007 | 12:26 AM
philipwight's Avatar
Default Front bumper for BIG intercooler.
Does anyone make a good looking (close to stock) front bumper that will fit a big intercooler. a stock bumper will not fit. For an EG chassis.
Old Jun 15, 2007 | 03:26 AM
red_crx's Avatar
Default Re: Front bumper for BIG intercooler. (philipwight)
do you have pics of how big it is..or measurements?
Old Jun 15, 2007 | 04:10 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone make a good looking (close to stock) front bumper that will fit a big intercooler. a stock bumper will not fit. For an EG chassis.</TD></TR></TABLE>
good question! i need one too.
Old Jun 15, 2007 | 04:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Front bumper for BIG intercooler. (Mikey3000)
22 x 11 x 3 fits my stock bumper.
Old Jun 15, 2007 | 05:20 AM
tony1's Avatar
Stock bumper. 24x12x3.5
Old Jun 15, 2007 | 07:09 AM
ykracing's Avatar
Default Re: Front bumper for BIG intercooler. (tony1)
my huge IC fits the stock EG bumper too... (dont have pics, but its the biggest one vibrant offers)
Old Jun 15, 2007 | 07:55 AM
SinglecamMitch's Avatar
Default Re: Front bumper for BIG intercooler. (ykracing)
mines 3" fat and pretty tall... you just gotta cut it to your own likings....
Old Jun 15, 2007 | 08:35 AM
g23_ej1's Avatar
Default Re: Front bumper for BIG intercooler. (SinglecamMitch)
mines 31x12x3 and fits just fine..
Old Jun 15, 2007 | 01:30 PM
I.C.C.'s Avatar
24x12x3.5... trimmed up stock bumper
Old Jun 15, 2007 | 04:16 PM
Topdawgg's Avatar
precision 750 hp intercooler.. stock EG bumper.. no problems
Old Jun 15, 2007 | 04:17 PM
eg:R's Avatar
Default Re: (I.C.C.)
32x10x3.5
Old Jun 15, 2007 | 05:09 PM
nsxmatt's Avatar
Default Re: (eg:R)
Biggest Vibrant IC, stock bumper fit with just cutting out the unpainted part of the grill.
Old Jun 15, 2007 | 06:20 PM
HiProfile's Avatar
Default Re: (nsxmatt)
I think the OP is looking for a premade bumper, not having to do something as tidious as actually cutting OEM plastic.
Old Jun 15, 2007 | 06:26 PM
Bailhatch's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I think the OP is looking for a premade bumper, not having to do something as tidious as actually cutting OEM plastic.</TD></TR></TABLE>
tedious? it's plastic, it cuts like butter. It's a lot easier than making some pos fiberglass bumper even fit right, not to mention the surface prep and paint work needed.
Old Jun 15, 2007 | 07:27 PM
nsxmatt's Avatar
I took a utility knife and about 5 passes, took all of 30 minutes. It'a alot easier and cheaper than buying, painting, and still having to cut a aftermarket bumper. I was under the inmpression the OP didn't know what types of IC's could actually fit behind a stock bumper and would save him some money and time.
Old Jun 15, 2007 | 09:29 PM
quik sol's Avatar
for the guys cutting, I am planning to cut my stock sol bumper, but am nervous. Did you guys cut right at the paint/unpainted line? any tips? I really don't wanna screw up my bumper.
Old Jun 15, 2007 | 09:34 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Stock bumper. 24x12x3.5</TD></TR></TABLE>
LOL, there's nothing left!
Old Jun 16, 2007 | 05:38 AM
nsxmatt's Avatar
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">for the guys cutting, I am planning to cut my stock sol bumper, but am nervous. Did you guys cut right at the paint/unpainted line? any tips? I really don't wanna screw up my bumper. </TD></TR></TABLE>
I cut right at that line. Use a sharp utility knife and make a bunch of slow clean passes all the way around till its all the way through. If you use a die grinder or other powered saw it tends to melt the bumper as you cut and looks rough.
Old Jun 16, 2007 | 06:08 AM
Mr. Badwrench
on cutting out the middle, the black unpainted stuff, i used a sharp utility knife, on the 2 upper holes, i used a 2" holesaw and an ingersol rand air saw.
Old Jun 16, 2007 | 06:34 AM
tony1's Avatar
Default Re: (boostedcivicsir)
Ok, i talked to Phillip, he wants to run a 24x12x4.5" core, and he has a full race divided top mount with 2 44mm gates. The gates stick out past the core support a little, so fitting a 4.5" thick core would leave you with nothing on the bottom part. So, what he's looking for is a bumper with some more clearance across the bottom lip. Anybody seen anything?
Old Jun 16, 2007 | 06:54 AM
Turbo-charged's Avatar
Default Re: (tony1)
it took me FOREVER to get this to fit like that. i spent a whole hell of a lot of time mounting the intercooler to get it to fit. and as much as i didnt want to do it, i mad to ""modify" my full race manifold to get one of the wastegates to position a little differnt so that the intercooler would fit the way it did. i even went as far as modifying the headlights to position the ic that way.
as far as a 4.5 core....i havnt seen any bumper that sticks out far enough to accept that. i'd think that the core its self would be fine....i'd just imagine the end tank/charpe pipe area would be the problem. could you do a dual back door sorta deal? i guess 4 inch DP woudlnt allow for any movement of the radiator.
Old Jun 16, 2007 | 07:01 AM
tony1's Avatar
Default Re: (Turbo-charged)
Looks like the bottom lip on your bumper is less than 1" deep Joe, is it? If it is, then an inch thicker core wouldn't fly, assuming your ic is back as far as it can go. I can make the tanks fit, just have to come out and back instead of just straight out.
Old Jun 17, 2007 | 08:11 AM
Default Re: (tony1)
i'll have to measure it...it will be close for sure.
does that deep of an IC fit on an integra easily or is it still a PITA?
Old Jun 17, 2007 | 09:30 AM
tepid1's Avatar
An Integra has a lot more room behind the bumper than an EG does.... 4.5" is no problem.
Old Jun 17, 2007 | 09:47 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i'll have to measure it...it will be close for sure.
does that deep of an IC fit on an integra easily or is it still a PITA?</TD></TR></TABLE>
Yeah, i have a 3.5" core and i moved it really far forward to keep plenty of space behind it for airlow out of the core, i could easily fit a 5.5" core!
