B16/crx going to REF. What intake to use?
Old Jun 14, 2007 | 11:57 PM
Arbiter's Avatar
Default B16/crx going to REF. What intake to use?
I've got a jdm b16a in a 91 crx. The battery seems to be in the way of an intake. The car is going to be ref'd soon, need help with which intake to use thats carb legal. Thanks
Old Jun 15, 2007 | 12:13 AM
mr.speaker's Avatar
Default Re: B16/crx going to REF. What intake to use? (Arbiter)
do you still have the stock intake box and arm? if so you use that and just cut a little off the arm to make it fit
Old Jun 15, 2007 | 07:31 AM
BumbleBee Tuna's Avatar
dam, yeah, i almost got my 90 jdm b16a ref too, just because i had an exhaust check to take care of! but paid it and the hell with the ref! but for you my friend, if you still have that lil d series airbox & arm, you can push that onto the b16 stock throttle body! takes a little force but it works fine! [IMG][/IMG] how do you put photos up? i have a pic of mine! i can show but cant figure out how to post it yet
Old Jun 15, 2007 | 07:34 AM
Pee Wee's Avatar
Default Re: B16/crx going to REF. What intake to use? (BumbleBee Tuna)
stock box, 99-00 si arm
Old Jun 15, 2007 | 10:01 AM
Arbiter's Avatar
Default Re: B16/crx going to REF. What intake to use? (Pee Wee)
Thanks everyone. Dont have the stock airbox or arm but will start my search for stock airbox and 99-00 si arm
Old Jun 15, 2007 | 10:17 AM
Golden Eagle's Avatar
if its getting refed good luck they know the motor swaps now and a jdm b16 will not pass unless you get lucky
Old Jun 15, 2007 | 11:07 AM
sneakerfern's Avatar
Default Re: B16/crx going to REF. What intake to use? (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">do you still have the stock intake box and arm? if so you use that and just cut a little off the arm to make it fit</TD></TR></TABLE>
exactly what i did
Old Jun 15, 2007 | 11:52 AM
vw eater's Avatar
Default Re: B16/crx going to REF. What intake to use? (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">if its getting refed good luck they know the motor swaps now and a jdm b16 will not pass unless you get lucky </TD></TR></TABLE>
the jdm b16a will pass ref, you just have to do it correctly, new intake manifold, skunk2 or a oem del sol, and a header, dc or oem del sol. and a usdm p30 ecu(good luck on that)
Old Jun 16, 2007 | 04:49 AM
Arbiter's Avatar
Default Re: B16/crx going to REF. What intake to use? (vw eater)
No luck necessary. I've got everything I need. Except the intake
Old Jun 16, 2007 | 08:40 PM
vw eater's Avatar
i have a intake you can use, p30 usdm and tb, just leave a deposit
Old Jun 16, 2007 | 09:43 PM
michael O's Avatar
Default Re: (vw eater)
Just use a 99-00civic si CAI. That's what I did. Mine always managed to pass visual but never the emissions portion.
Old Jun 17, 2007 | 12:45 AM
Arbiter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw eater &raquo;</TD></TR><TR><TD CLASS="quote">i have a intake you can use, p30 usdm and tb, just leave a deposit</TD></TR></TABLE>
That sounds good, where are you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapa haole &raquo;</TD></TR><TR><TD CLASS="quote">Just use a 99-00civic si CAI. That's what I did. Mine always managed to pass visual but never the emissions portion. </TD></TR></TABLE>
Can I borrow your cai?
Old Jun 17, 2007 | 07:19 PM
vw eater's Avatar
Default Re: (Arbiter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arbiter &raquo;</TD></TR><TR><TD CLASS="quote">
Can I borrow your cai?</TD></TR></TABLE>
iam in sandiego
Old Jun 19, 2007 | 05:46 AM
yeah, just using a cold air intake from aem, not the hybrid though, should be fine as it is carbed
Old Jun 19, 2007 | 12:26 PM
Arbiter's Avatar
Default Re: (BumbleBee Tuna)
So the cold air intake by AEM for a 99-00 Civic Si?
Old Jun 19, 2007 | 04:52 PM
i am not quite sure about the year because of the piping in the engine bay. I would try with the aem cai for the crx d16 and im sure if problems accure, it would only be the fitment near the throttle body, but you can always fix that silcone
Old Jun 19, 2007 | 05:35 PM
tigerjuice's Avatar
I would like to know this info as well.
Old Jun 20, 2007 | 06:50 AM
Default Re: B16/crx going to REF. What intake to use? (tigerjuice)
i was about to get my car reffd as well, all i needed was the ecu and intake manifold! i have jdm 98spec type r headers with no heat sheilds on it, they check the engine bay first, didnt even mention anything about it! the only reason why they turned me away was because my car had no reverse! but silcone with aem intake for the dseries motor should work just fine! if not, just get your self the stock airbox and arm from the junk yard
Old Jun 20, 2007 | 06:52 AM
anybody know how to post pics? i can show you a pic of me motor!
Old Jun 20, 2007 | 07:14 AM
nvm! got it! [IMG][/IMG]
vtec_ef8
Aug 9, 2008 10:49 PM
VegaS10
Apr 14, 2006 09:29 AM
SubTitle
25
Apr 20, 2005 06:41 PM
iBear
Oct 12, 2004 05:58 PM
K_1
17
May 29, 2002 11:12 PM
