Map Sensor on firewall. Need a pic of resistor box.
Old Jun 14, 2007 | 11:42 PM
RockinthEFhatch's Avatar
Default Map Sensor on firewall. Need a pic of resistor box.
I'd like to know how to remove that cluster of crap that the map sensor plugs into. Well I could easily remove it, I mean where do I put it? Do I need to extend wires? I've got a map sensor on my throttle body and want to connect it there. I also need a close up of the resistor box on a CRX. Thanks guys!
Old Jun 15, 2007 | 12:37 AM
mr.speaker's Avatar
Default Re: Map Sensor on firewall. Need a pic of resistor box. (RockinthEFhatch)
yeah you extend the wires to reach the throttle body mounted map sensor...Then if you want to you can remove all that **** on the firewall,the map sensor,vacuum lines,purge solenoid, and the charcoal canister. I wouldnt remove the purge solenoid and charcoal canister unless you have a hook up for an inspection sticker though.
89' si resistor box
Modified by mr.speaker at 4:48 AM 6/15/2007
Old Jun 15, 2007 | 12:45 AM
Default Re: Map Sensor on firewall. Need a pic of resistor box. (mr.speaker)
Really appreciate it man. That stuff is going tomorrow.
Nice pics too but I meant I needed a picture of the resistor box installed in the bay - I'm sorry. Like how the damn clips go from the factory. I put it back after painting it flat black and I clipped it goofy as hell.
Old Jun 15, 2007 | 12:48 AM
mr.speaker's Avatar
thanks to fourthgenhatch.net
Old Jun 15, 2007 | 12:49 AM
Honest to god though, that was the best answer I've ever got from any question I asked. Simple to the point.
Old Jun 15, 2007 | 12:53 AM
Default Re: (RockinthEFhatch)
So the big white one just chills? Doesn't get clipped again? Seems to look much better. Haha that's actually exactly how mine will look. Mr. Speaker, you are a god amongst men. I should just log on at 4 am more often to talk to you!
JDM-sol 89
Nov 2, 2011 01:59 PM
stocker2shocker91
Dec 19, 2006 07:42 PM
jimmyv
Oct 4, 2006 07:41 PM
pdiggitydogg
May 6, 2006 02:24 PM
juicy.koreans.suck
Mar 7, 2002 12:08 PM
