Electric Problem
A couple days ago I drove my car and it kinda bogged out a little bit, like the engine was running but there was just no power going to the wheels. I drove it maybe 100 yds and parked it for 2 hours. When I came back it wouldn't start but everything electric in the cabin was fine and I smelt smoke. I checked under the hood and my positive battery wire to the starter was burnt up around the starter and burnt some of my engine harness. I replaced the battery wire and connected everything and I saw more smoke come from around the starter and now nothing in the car works except the horn. I'm replacing the whole engine harness tomorrow and from reading it looks like I need a new starter. Is there anything else I should look into replacing? I have an eg w/a z6 and the main relay was also replaced about 6 months ago if that helps any. Thanks in advance.
I think you've got urself a prob. there buddy. Have you installed anything else on your car recently that had to do with the wiring? Check all your wiring, relays, fuses and grounds. Just to make sure you dont have a short somewhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8db8db8 »</TD></TR><TR><TD CLASS="quote">I think you've got urself a prob. there buddy. Have you installed anything else on your car recently that had to do with the wiring? Check all your wiring, relays, fuses and grounds. Just to make sure you dont have a short somewhere. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8db8db8 »</TD></TR><TR><TD CLASS="quote">Is it thrown a CEL?</TD></TR></TABLE>
check those out and if you still cant trouble shoot it id pony up the money and take it to a specialist...i hate wiring problems. gl
Nothing has been done to the wiring since the z6 was dropped in and it was running perfectly fine since march. There were 2 grounds taken off and that's how many were put back. Is it possible for grounds to go bad or for the harness to go bad?
westsideconnect
Feb 23, 2009 02:34 PM
Maireeka
13
Dec 6, 2006 12:32 PM
CrX-To-Tha-Max-v2.0
Dec 1, 2005 06:38 PM
tree
Sep 21, 2003 04:45 PM
