2 min pulley job
im trying to take off my pulley...i dont have that one tool to take it off....i saw a post about taking it off in 2 mins but i cant find it now...wondering if anyone knows that way...or any other way to take off my pulley...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">A good impact gun will remove a crank pulley in a couple of seconds. </TD></TR></TABLE>
Those things are torqued on there tight you just need the right combination of tools. Either a good impact gun or they sell a tool that holds the pulley in place while you loosen it.
i dont have a gun to take it off.....there was a post saying "2 min pulley".....without the gun...cant find it...anyone know how to take it off without a gun?
Yeah I used a breaker bar before, if it's too hard you can use a bolt lay it side to side to the crank bolt. "Like if your trying to put a nail on the wall" give it a couple of solid hits with a hammer and try to remove the bolt. You can also use a torch to heat up the bolt a bit those are some techniques I've used before I purchased my compressor.
i have a breaker bar around this size http://www.4x4wire.com/toyota/...think thats an ok size to take it off?
oops....heres the site http://www.4x4wire.com/toyota/...2.jpg should that breaker bar work without the chain to hold the pulley?
djnikko
19
Apr 24, 2005 07:43 PM
