b16a SiR motor in my 89 civic hatch, need help finding bolt-on hydraulic tranny options...
Old Jun 14, 2007 | 10:39 PM
the b man's Avatar
Default b16a SiR motor in my 89 civic hatch, need help finding bolt-on hydraulic tranny options...
Hi, I have an 89 Civic hatch with a JDM B16a engine and tranny out of a civic SiR, and the clutch is failing. I have owned mostly newer vehicles with hydraulic tranny's, and I do not care for this cable driven tranny much at all, its just clunkier and harder to shift with altogether compared to a hydraulic tranny. I am hoping somone can tell me which car's with hydraulic trannies will bolt up to my b16a, and will be able to handle turbo power, as my engine is turbo'd. I figure since the clutch is going, I might as well get the tranny I want at the same time. Thanks for the help!
Old Jun 14, 2007 | 10:45 PM
civicstar's Avatar
Default Re: b16a SiR motor in my 89 civic hatch, need help finding bolt-on hydraulic tranny options... (the
this is one of another debates of peoples opinions but since u ask. you will end up needing a cable to hydro conversion kit and many people have opinions of gear ratios and that is up to u, if u like the LS long gears or the type R short gears. the 94+ LS integra will fit, or the gsr 94+ will fit or the 99 si b16 transmission will fit, then there are the type Rs
Old Jun 25, 2007 | 08:10 PM
the b man's Avatar
cmon guys, theres GOT to be someone out there with this info... help please...
Old Jun 25, 2007 | 08:12 PM
the b man's Avatar
oops my page didnt refresh properly, thanks for the info! where can I get this conversion kit? also, what do you mean by this is one of those "debates"? care to explain?
Old Jun 26, 2007 | 07:39 AM
dblock2x's Avatar
Default Re: (the b man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.hasport.com/products/mount_kits/efb2.htm &raquo;</TD></TR><TR><TD CLASS="quote">
Price $499.00
EFB2
Here is yet another kit everyone has been looking for. The all new Billet EFB2 mount kit. The mounts are milled from lightweight ultra strong T-6061 aluminium billet and have a lifetime warranty. Besides being the best looking and strongest mounts on the market, we have made some changes in engine placement.
These mounts make B-series engine swaps into the 88-91 Civic or CRX a simple, bolt-in process. The kit is designed to work with the B-series engine and the hydraulic transmission.
Every kit is engineered to race specifications. Engine movement is minimized by controlling the durometer of the polyurethane bushings, and as such, only 3 mounts not 4, are required for the engine swap.Three durometers of bushing stiffness are available at no additional cost. When ordering, specify whether you want "Street", "Race", or "Extreme Race" stiffness. The urethane bushings also have a lifetime warranty.
* CAD/CAM Designed.
* Proper engine placement and axle angle.
* 6061 T-6 billet aluminum
* 62A, 70a, and 80A urethane.
* Lifetime Warranty.
lilo_goki
Nov 13, 2007 05:46 PM
worrdogg1
Apr 26, 2003 09:42 AM
88vtec
Nov 22, 2002 05:22 PM
