clutch
Old Jun 14, 2007 | 09:01 PM
veritasaequatis's Avatar
Default clutch
what is the easiest way to do this , mind you i cant take the engine and tranny out ( not enough space or time) just need some insight
Old Jun 14, 2007 | 09:35 PM
cr-x-91's Avatar
yeah.........drop the tranny and buy a clutch and alignment tool. And there is a write up on doing a clutch. Not to hard.
Old Jun 14, 2007 | 10:09 PM
crxnj's Avatar
Default Re: clutch (veritasaequatis)
theres actually a good writeup on crxcommunity.com,,you just have to sign up to see it.
this job is easy when you have the right tools..for example a pittman arm puller for the lower ball joint,,12 point sockets for the clutch and flywheel bolts,,8mm punch for the pin shift linkage pin,,various extentions,,AND ANOTHER PERSON WHEN PUTTING THE TRANNY BACK ON THE MOTOR
killa4lyfe
Sep 3, 2006 03:48 PM
kinoukiita
Jul 24, 2006 09:58 PM
invboost
Nov 15, 2003 11:41 AM
daver
Jul 31, 2002 05:24 AM
