C5 into a crx already has A1 mount and axle q's
could i use my motor mounts that i am currently using on my A1 setup? i plan on getting a hydro tranny with it... so i use integra axles/ the ones that go with the engine/half shaft/tranny? i have 91 teg knuckles on the car , and i know i have to rewire for vtec and OBD(x)..... so recap
# which axles?
# can i use same motor mounts?
# what is involved in the hydro conversion? is is worth finding a cable tranny?... i am not a "dragger" or "racer" i just enjoy performance
i did do a search for mounts and couldn't find much but did notice on hasport site that all b series mounts are the same i guess...
searched axles and found that to use teg but it was specific what model....
# which axles?
1. just like normal,,you match the axles with the halfshaft,,if you want to you re-use the axle and hafshaft setup you have now on the new b18c motor and tranny,you can..Just realize you'll need a hydro axle seal or you may get leaks.
2. You'll need a mount for the hydro tranny,cable tranny is different.
3. Now days its as simple as this http://www.innovativemounts.co...41000
And it's not even worth finding a cable tranny,,none compares to the type-r execept for the 92-93 gsr and you won't find one unless you're lucky....
pigeonnn
Jul 28, 2011 12:10 PM
Kasper.
Jan 31, 2004 12:28 AM
