Progress springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1staecksauce »</TD></TR><TR><TD CLASS="quote">no, I just dropped my car 1.4 inches on Eibach Sportlines and you don't need a camber kit.</TD></TR></TABLE>
LOL you sure mine is dropped on sportlines and its almost tucked front and back i am def getting a camber kit !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C Squared »</TD></TR><TR><TD CLASS="quote">Toe zero for your alignmienrt and you should be fine.
Front or rear? And does anyone think I will rub with with 17 x 8 rims with a 45mm offset?
</TD></TR></TABLE>Front or rear? And does anyone think I will rub with with 17 x 8 rims with a 45mm offset?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote">You will need one. I have Progress and my rears wore out within 6 months</TD></TR></TABLE>
How many miles did you drive on them before they wore out?
Did you have it properly aligned? My tires are just dandy after 4 months with the toe set to zero.
With the car lowered, My back tire was hitting 75% of the road. In stock form the car has alot of camber. Yea toe eats tires, but camber will do it too. If camber wasnt an issue, why do they make kits?
Take a look at stock form, then when it is lowered. You will see a big differance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote"> If camber wasnt an issue, why do they make kits?
Because people that don't know any better will buy them.
In some cases it's necessary. With these springs it's not. HTH.
taimysho0
Feb 6, 2008 08:14 AM
