ASR subframe install on EK, one question?
Old Jun 14, 2007 | 07:48 PM
ke98248's Avatar
Default ASR subframe install on EK, one question?
I've got my car jacked up and jackstands under it so I can install my A-Spec ASR Subframe bar.. I checked out the directions from Password JDM, and they don't mention anything about switching the shock 180 degrees (so the welded nut is facing rearward) like 2 of the walkthroughs on H-T do. Is there a really important reason to do this or not?
from https://honda-tech.com/zerothread?id=1906897
Old Jun 14, 2007 | 08:07 PM
BlueIntegraBoy's Avatar
Default Re: ASR subframe install on EK, one question? (ke98248)
It doesn't matter.
Old Jun 14, 2007 | 08:10 PM
ke98248's Avatar
Default Re: ASR subframe install on EK, one question? (BlueIntegraBoy)
how do you know, have you installed it before? Just want to be sure
Old Jun 14, 2007 | 08:46 PM
ke98248's Avatar
Old Jun 14, 2007 | 08:52 PM
sicones's Avatar
thats only when your installing the crappy ST swaybar where the endlinks bolt to the lower shock bolt, if your installing an ITR bar of none at all don't worry about it
Old Jun 14, 2007 | 08:53 PM
ke98248's Avatar
Default Re: ASR subframe install on EK, one question? (sicones)
Funny, cause Eran did it in his post (that's where the pic was grabbed from).. Anyways, thanks.
Old Jun 15, 2007 | 01:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">how do you know, have you installed it before? Just want to be sure</TD></TR></TABLE>
Yes, I have using an ITR bar. But as sicones mentioned, I guess it's essential for the ST bar.
Old Jun 15, 2007 | 05:23 AM
95ProjectEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Funny, cause Eran did it in his post (that's where the pic was grabbed from).. Anyways, thanks.</TD></TR></TABLE>
Didnt Eran use the ST bar? And if what everyone is saying is true, than that would explain why he did the 180 on the shocks.
Old Jun 15, 2007 | 05:59 AM
Eran's Avatar
HT White Ops
I only did that for the ST bar install. It has nothing to do with the ASR brace.
And I wouldn't call the ST bar crappy by any means. The fitment is great, the handling is improved dramatically. Is there really anything else you need from a sway bar?
Dc2 Strogg
May 28, 2012 05:43 PM
CTRwannaB
Apr 23, 2006 10:51 PM
OneSloTeg
Oct 9, 2005 11:40 PM
1black_lude
Jun 11, 2005 11:50 AM
96Prelord
Jan 25, 2003 01:05 PM
