Checking codes--98 Accord OBD2 with OBD1 swap and a P72 computer?
I have a 98 Accord coupe with an H22a turbo using a P72 computer. The check engine light is coming on. How do you read codes when there isn't an SCS connector to jump? Anyone know how?
Thanks,
Thanks,
I don't have the pinouts any more for the P72, but all you need to do is find out which pin of the ECU goes to the SCS connector. Then short that wire to ground. That's exactly what happens when you jumper the SCS connector.
CivicSpoon
Apr 27, 2008 06:00 PM
