Nabi's Offical For Sale Thread
BUMP IF YOU VIEW!!!if you buy something and are satisfied leave me some love in my vouch thread...
http://www.hondamarketplace.co...3923
NEED EVERYTHING GONE!!!
NEW PICTURES AND NEW STUFF ADDED!!OPEN FOR most TRADES!!
FOR SALE:
Turbo Stuff!! ------>-STR Fuel RAIL - B series - blue - 50
-Apexi Turbo timer - old skool - 40 obo
-REV HARD FMIC (3.5 x 20.5 x 7.75 this is just the fin area) - 225 obo
-Dual Gauge pod for EK pillar- 10
-38mm TIAL wastegate - 180 obo
-AUTOMETER A/F gauge - 35 obo
-Greddy FPR - 45
Aftermarket parts ----- >-4 LS eagle rods (one had spun rod bearing - i would suggest repalcing all bearings anyway) - 100 OBO
-CTR crank pulley - 65 obo
-"OH VTEC" B16 valve cover (bright red) - 100
-Powder coated WHITE gsr valve cover - 75 has two small chips
-INFINITY speaker covers - 10
-AEM CIA for EK/EG - BLUE - 100 obo
-B16 AEBS IM painted black - 130 plus your stock IM
**cable to hydro coversion!!! - 100 OBO comes with everything you need to use a cable tranny in an EG or DC (comes with "Place" mount, custom arm for throw out, and slave cylinder!)
--MINT CTR rear seat (its pictured in a 00 hatch) same material as recaro seats - 250 obo (can work something out with stocker)
--01 ITR tranny (was purchased STRAIGHT from HONDA and has approximately 16k on it! - SHIFTS LIKE BUTTER!) - 1300 FIRM!!!!! will trade for gsr with quaife or OBX plus cash - the only reason i am selling this is because im trying to make 500 whp and i havent heard good things about itr transmissions at high HP. This tranny is mint and has never see more than about 170whp (gsr with itr cams and bolts ons) the miles are daily driving mostly done by a female driver
so its been babied!-stock EL seats (have leather head rests same bolt pattern as ek) - 150
MAKE OFFERS ON EVERYTHING BELOW ----->
ALL PARTS MUST GO!!
ECUs ------->-OBD2 - OBD1 wiring harness - 55 obo
-CTR ECU - B16B - OBD2 JDM - 275
-OBD1 P28 ecu - 100 firm!
-99-00 P2T DOHC SI ecu - 150 obo
Integra Parts ----->
-FULL set of GSR leather seats (front + back) MINT - from 00 GSR - 400
-GSR front seats (have some wear on outer sides - no tears or holes) - 250 obo
-GSR FRONT AND REAR BRAKES - 350 (drilled and slotted front rotors - NEW PADS!)
-passengar 98 integra caliper - 10
Audio--------->
-2 ~ 12 inch Jl subs in a carpeted box - 120 obo
-400 watt Coustic amplifier - 2 channel - 75
-Carpeted box for two 10 inch subwoofers - 35
B series PARTS--------->
-B16A2 long block (legit with VIN) - 700 obo
-Bseries flywheel - 35 obo
-Bseries flywheel - needs resurface - 20
-ACT Xtreme Pressure plate - used - 50
-!!Bseries shift linkage - 55 OBO!!
-Bseries throw out - 20
-Gsr rear T-bracket - 25
-Fork for throw out - 20
-GSR HEAD STUDS (stock)- 10 ( i have three sets!!)
-B series working thermostat - 5
Gsr timing covers - (USDM or JDM) (prices for upper and lower together)- 65 obo for the JDM cover, 55 obo USDM
-upper gsr timiing cover (JDM) - 25 (i have two)
-OBD2 GSR wiring harness - 125 obo
-Gsr stock spark plug wires (very good condition) - 25
D series stuff ---> (40 bucks for this whole section
)-D series flywheel - 20 obo (i have two!!)
-Dseries starter - manual - 20
-D series driver side two bolt mount - 5
EG Parts ----->
-EG coupe teal gas door - 5
-black stock center consol - 20
-Black door handle covers for EG - 5
-EG front upper control arms - 15
-EG hatch stock side mouldings - 60 obo
-frost white EG side mirrors (driver and passengar) - 40 obo
-EG HATCH rear 1/4 panel windows - 40 each or 70 for both sides
-manual window crank for EG - passenger side - 10
-EG sprayer tank and motor - 15
-Civic shift boot - 3 or free if you buy more stuff!
CRX, EF & DA - obd0 parts ------> - All the OBDo stuff - 20 dollars!
-CRXsi visors - 10 obo
-ls power steering pump - 20!!
-Black CRX fuse box cover - 10
Electornics ------>
-Plantronics 640 Bluetooth 100 dollar value - 60 obo
[b]-CINEGO home theater digital projector - 400 (plays dvds and has built in speakers)[b] - picture can go from small like a tv to filling an entire wall! ONLY USED YOUR 2 MONTHS!
I WANT TO BUY/TRADE FOR:
-NEW aftermarket rods + rod bolts (need these for an LS crank)
-ARP GSR main studs + aftermarket girdle
***Id much rather trade parts rather than have to buy all this stuff!
CINEGO!!
AEM CIA
12 inch Jl subs and box
White GSR valve cover - kinda dirty SORRY
Black door handle cover EG - 5 dollars
STock side mouldings (both sides included - 60 obo)
D series Flywheel
GSR Timing covers (JDM and USDM)
EK Gauge pod
B series thermostats
CRX si visors
ls power steering pump OBD0
Passenger Manual window Crank
stock washer with motor
shift boot
crx fuse box cover
BOx for two ten inch speakers - 35 bucks - AMP sold separately!!
Gas tank cover for EG
front support for civic
CTR rear seats
Greddy FPR
CABLE TO HYDRO KIT!!
STR Fuel RAIL
Bseries flywheel - looks lightened to me
Stock center consol
Bseries shiftlinkage
Gsr caliper
Frost white STOCK mirrors
AF gauge
OH VTEC!! and AEBS IM for B16
B16 longblock - AEBS IM and DC header not included
GSR brakes
Modified by nabin at 2:07 AM 4/22/2008
Do you still have the lsvtec and gsr tranny. If so, how much extra for you to deliver to San Antonio?
