cel 16?? not one flash then 6 fast ones. its just 16 quick flashes wtf??
it runs messed up and dies then the ecu flashes 16 times realy quick no pause in between them i belive obd0 is like obd1 where a code 6 would be 1 long flash then 6 quick ones but this is odd
any one ever seen this?
tried another ecu and get a map sensor code #5 (could this be becouse its on a t conneced to the fuel pressure regulator to?)
and a vtec spool solinoid #21 (this i know is becouse its not connected)
Sure all your grounds are good ? As for the map sensor and wiring diagram, just follow the one thats in the archives.
Sorry I ment the vacuum diagram, follow the one on h-t . There is one around that is used to show how to run the wires.
its not a code 16 i found that out it was a messed up ecu i think
now its a map code that i got to go away by removing the t where it was conneced with the fpr now its just a code 21 but it still idles messed up i dont know why though no leaks that i can find all vacume lines are tight
