uhh, idle afr suddenly in the 10's...what else to check??
Old Jun 14, 2007 | 02:57 PM
blackeg's Avatar
Default uhh, idle afr suddenly in the 10's...what else to check??
lsvtec running uberdata, precision 780s and an oem integra resistor box.
2 days ago i noticed my idle was down like 5" and low rpms. my plugs are totally black and the wb is now saying 10s. car ran fine on my way into work that day. so far i reburned my chip and its still doing it. im gonna get a new resistor box tomorrow, but if that doesnt work what else should i try?
Old Jun 14, 2007 | 03:39 PM
A.E Motoring's Avatar
Default Re: uhh, idle afr suddenly in the 10's...what else to check?? (blackeg)
i had a similar issue, i couldnt figure it out for the life of me, so i went back to the tuner, and see if he could fix it, had him retune the whole car, and only thing he changed was to disable the o2 sensor, and it was perfect after that, o2 prolly going wacko
Old Jun 14, 2007 | 06:39 PM
blackeg's Avatar
Default Re: uhh, idle afr suddenly in the 10's...what else to check?? (Dual Cam Racing)
hmm. i dont run an o2 (open loop for life lol). kinda sucks that i am the tuner, so i cant bring it back somewhere...
Old Jun 14, 2007 | 06:47 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">kinda sucks that i am the tuner, so i cant bring it back somewhere...</TD></TR></TABLE>
haha that's classic
Old Jun 14, 2007 | 11:27 PM
vw1320's Avatar
The only thing you need to check is Evan's calander for the next open appointment.
Old Jun 14, 2007 | 11:59 PM
SOHC_MShue's Avatar
sounds like your map sensor is getting an atmospheric pressure signal all the time. Check that out and make sure everything is still fine with the wiring and the vac source.
Old Jun 15, 2007 | 03:26 AM
blackeg's Avatar
Default Re: uhh, idle afr suddenly in the 10's...what else to check?? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your map sensor is getting an atmospheric pressure signal all the time. Check that out and make sure everything is still fine with the wiring and the vac source.</TD></TR></TABLE>
ok good advice. ill hit this up when i get home from work today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw1320 &raquo;</TD></TR><TR><TD CLASS="quote">The only thing you need to check is Evan's calander for the next open appointment. </TD></TR></TABLE>
haha late august, right after i get done teaching summer school
Old Jun 15, 2007 | 03:28 AM
red_crx's Avatar
I think thats what it is....I had the same problem and thats exactly what it was
Old Jun 15, 2007 | 08:37 PM
blackeg's Avatar
Default Re: uhh, idle afr suddenly in the 10's...what else to check?? (red_crx)
alright. i put in a new resistor box. no luck
also ran a new map sensor vacuum hose. the map sensor wiring looks good. all the solder connections are still solid. im using an sve 3 bar if it matters.
i also noticed that my afr while driving is about a point richer than it usually is. ie when im 15" and 3000 rpms where i used to be about 14.5 im now like 13.7
Old Jun 17, 2007 | 07:59 AM
blackeg's Avatar
contemplating getting another map sensor.
any other ideas?
Old Jun 17, 2007 | 08:57 AM
boosted k20's Avatar
change the plugs and did this recently started to happen since the weather got warmer? i had to retune my car on when the temps got hotter (i live in NY as well)
is your vacuum at idle 5"???? if thats the case then somethings def. wrong.
Old Jun 17, 2007 | 09:29 AM
DaveF's Avatar
have you checked your Fuel pressure and your fuel pressure regulator?
Old Jun 17, 2007 | 09:58 AM
blackeg's Avatar
Default Re: uhh, idle afr suddenly in the 10's...what else to check?? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">have you checked your Fuel pressure and your fuel pressure regulator?</TD></TR></TABLE>
yeah i have a gauge right on my rail, its normal to what its always been, around 45 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">change the plugs and did this recently started to happen since the weather got warmer? i had to retune my car on when the temps got hotter (i live in NY as well)
is your vacuum at idle 5"???? if thats the case then somethings def. wrong.</TD></TR></TABLE>
haha no, its not at 5". normally my car pulls 24" dead on at idle, now it searches for idle from around 20-22". it happened on monday i think. i drove it to work fine, then noticed it when i pulled in for gas on the way home about 8 hours later.
the car still drives relatively smoothly, just the afr is busted up, again mainly at idle
Old Jun 17, 2007 | 10:12 AM
DaveF's Avatar
how old is that sensor you are using(WB02)
Old Jun 17, 2007 | 05:15 PM
blackeg's Avatar
wideband sensor is a few months old. when i was on the dyno about a month ago i verified its readings with the new dyno sensor.
i have had a wideband sensor go bad on me, and ive been very untrusting of them since, but i mean my plugs are jet black, from the ground strap to the fire ring..
thanks for the replies guys, im gonna keep troubleshooting, and your advice is helping me rule out and thing about places to check.
Old Jun 17, 2007 | 05:23 PM
THEDirtyDseriesWOOT's Avatar
sounds like a vac leak .. leaking boost as well making u run rich.. and making ur idle crap .. hook a boost leak tester up to ur car and find the leak
Old Jun 25, 2007 | 01:09 PM
blackeg's Avatar
Default Re: (THEDirtyDseriesWOOT)
ok so i got a new map sensor and changed my spark plugs- everything is fine.
so somehow my sve 3 bar **** out on me. it had maybe 12k miles, but i did just have it mounted under my intake manifold to keep my bay clean. i wonder if it just got to hot undere there for it. now ive got it up on the firewall
civicSiR1.6
Jun 20, 2018 11:48 AM
chris d
Sep 10, 2015 03:35 PM
ABCVTEC
May 22, 2007 12:37 AM
oldskooljdm
Dec 2, 2003 04:19 AM
VTC_CiViC
Jul 16, 2002 07:33 AM
