NA newbie build question about the crank....
Old Jun 14, 2007 | 01:54 PM
hndacord02's Avatar
Default NA newbie build question about the crank....
I did some searching, and didnt find what i wanted, sorry if its a repost.
Motor: b18c(jdm gsr)
Plans for internals are for proseries cams stg 1 or2, sk2 valvesprings, retainers, valves, ITR or b16 pistons.
all the basic bolts on including im. and tb.
When would you need to upgrade crankshaft? how much can the stock crank take safely?
Your help is greatly appreciated, thanks!
Old Jun 14, 2007 | 02:01 PM
Syndacate's Avatar
Default Re: NA newbie build question about the crank.... (hndacord02)
For the upgrades you're doing / have planned the stock crank will be fine...
Old Jun 14, 2007 | 02:40 PM
EM1_00Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndacord02 &raquo;</TD></TR><TR><TD CLASS="quote">I did some searching, and didnt find what i wanted, sorry if its a repost.
Your help is greatly appreciated, thanks! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">For the upgrades you're doing / have planned the stock crank will be fine...</TD></TR></TABLE>
Way to answer the question...
Old Jun 14, 2007 | 02:42 PM
Luserkid's Avatar
Default Re: NA newbie build question about the crank.... (EM100Si)
Stock honda cranks are used on 1200hp motors. What makes you think your basic build needs a different crank?
Mircopolish and balance it and call it a day
Old Jun 14, 2007 | 04:24 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Stock honda cranks are used on 1200hp motors. What makes you think your basic build needs a different crank?
Mircopolish and balance it and call it a day </TD></TR></TABLE>
bingo. only other reason to replace the stock crank is if you want to run a bigger than stock (92mm+) stroke.
Old Jun 16, 2007 | 03:12 AM
hndacord02's Avatar
Default Re: NA newbie build question about the crank.... (doood)
aight, sounds good! i just wanted to double check and see if i would need to replace it! thanks for your help guys!
Old Jun 16, 2007 | 05:34 PM
doood's Avatar
just make sure the crank is straight and hasnt spun a bearing
Old Jun 16, 2007 | 06:04 PM
ekb16's Avatar
send ur crank out to Laskey Racing to have them balance and micropolish for $150
Old Jun 21, 2007 | 07:17 PM
hndacord02's Avatar
Default Re: (ekb16)
do they have a website?
Old Jun 21, 2007 | 07:23 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (hndacord02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00Si &raquo;</TD></TR><TR><TD CLASS="quote">
Way to answer the question...</TD></TR></TABLE>
Nuff said, stock honda cranks are used for many high HP hondas.
I wouldn't pay $150 for a balance and micro polish, just take it to a local place.
Old Jun 21, 2007 | 07:30 PM
Luserkid's Avatar
Default Re: (ek forever guy)
Dan Benson has by far one of the best balancing out there. Only reason i would send it seperate from a block is because of the wait time. Other then that i would totally send it to Laskey for the balance.
pokmijn
Oct 16, 2008 11:12 PM
ej1252
Dec 5, 2007 05:35 PM
shivic
Dec 5, 2007 07:54 AM
Circuit Star-29
Feb 22, 2006 10:43 AM
HighRevn
12
Jul 16, 2004 12:35 PM
