jdm itr rear sway bar
i have a 00 gsr which has a 14mm rear sway bar and i want to upgrade with the 22mm jdm itr rear sway bar and i was wondering do i have to have also upgrade to jdm itr lca's?
so i searched and asr and beaks seem to be good subrace. which would be tha better buy? looks like everyone has asr. any experiences with beaks?
the beaks kit is fine... It does what its meant to do.
I dont think you really need the asr brace, its close to 3 times as expensive as the beaks.
I know a lot of people just get the asr for the whole bling factor.
I have the jdm itr rear sway with the beaks kit, and it is awesome.
The install is pretty easy, you just have to remove 2 tack welds, but everything other than that is a piece of cake.
the beaks kit seems to be made really well, and I can tell that there wont be any problems out of it.
You don't have to replace your lca to the itr ones. It is recimended that you get one of the subframe braces i.e. beaks, or asr as stated above and you should also get itr endlinks of aftermarket ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM se-R »</TD></TR><TR><TD CLASS="quote">You don't have to replace your lca to the itr ones. It is recimended that you get one of the subframe braces i.e. beaks, or asr as stated above and you should also get itr endlinks of aftermarket ones. </TD></TR></TABLE>
why get different endlinks?
I didnt, and its fine.
